73-79 Truck Parts
I have a lot of 73-79 Ford Truck Parts that I've acquired from 2 different trucks. WIll add more to the list as I dig parts up
-78-79 Grill Insert - $20 -AT Steering Column (Not Tilt, still has turn signal switch) - $30 -Matching fuel filler doors. Tan, off a 79 long bed - $10/set -Factory cruise control module off 79 460 (incl. bracket/harness) - $20 -Headlight doors (2 sets black, 1 set chrome) - $10/set -Lariat tailgate trim panel (1 small dent between the 'R' and 'D') - $20 -Speedometer Clusters (on off 78, one 79 w/unleaded fuel only label) - $20 each -Bumper Guards (Came off a 79) - $20 -Pair of factory supercab pop out windows - $30 -Motorcraft D9TE-AEA 4 bbl Motorcraft carb, came off a stock 79 460. It worked when I pulled it, but it could probably use a rebuild. $20 I have more things, so if you're looking for something specific that's not listed feel free to ask. All prices are OBO. I'm willing to ship small parts, but you'll have to pay for whatever size flat rate box I need to use. Will take cash or Venmo. I'm also in the market for a nice set of doors and a rust free bed for a 76 Highboy. Willing to do part trade. |
Do you happen to have a drivers side mirror bracket?
Also looking for drivers side front blinker cover for 79 f100 |
Originally Posted by 79f100beater
(Post 17223686)
Edited post.
interested in the chrome buckets are they for the round lights, those are what I need.
Do you have a 75 driver side door panel that takes the chrome trim? Don't care what color just as long as it's complete with no cracks.
Thanks tim |
Hello, looking for a parking brake return spring for 74 F250. 133" wheel base.
Original part number D2TZ-2A651-C Thanks! |
Do you still have the grille insert available? Also do you have the chrome grille surround available? I'm in SE Washington.
ISO a good copper/brass standard output heater core. Measures approx 6" X 7" X 2". Thanks!
79' Dash Cluster
Interested in 79' Speedometer Cluster. How much to ship to 70471? Thanks
Looking for factory rear bumper brackets for factory stock bumper 73-79 Thanks
Looking the shift linkage that connects the 4x4 lever to the transfer case
I'll take both of those supercab pop-out quarter windows if they are still available. Thanks!
is the column still avail?
Also looking for a section of the harness for turn signals, female side about 3-4" |
what's left?
