early 2004 6.0 no crank no injector noise
after installing a new oil cooler my 6.0 will not crank over and I have no injector noise or communication with my scanner , that is until I unplug the center connector to the PCM then injectors come on and engine cranks and pcm communicates with the scanner
You actually posted in the wrong forum. Maybe a mod can move this to the 6.0 forum.
I really am just guessing here, but did you get the ground wire put back on the intake stud behind the FICM? Kevin |
