Rare?
Hello all. Have trolled this site for quite some time based on my '66 F100 6cyl 'farm truck'.
Bought about a month ago in great basic shape (for me) and have been working on ever since. It's a '59 F250 2wd 292 with Factory cruise-o-matic (D2/D1/low) and power steering. All original. Been trying to educate myself on this vehicle, but have not seen another example. Is this rare? Seems common sense this particular vehicle would have been marketed as a work truck - was surprised to see the automatic. Any help/comment/feedback Appreciated! P |
Originally Posted by Pobo
(Post 17105721)
Those two options are pretty rare for a ½ton (F100), and I would think the production numbers are even less for a ¾ton!
Originally Posted by hardlyrider
(Post 17106293)
Working on it just good clean dirty Fun! |
(Post 17108798)
Thanks Hardlyrider! Have no intention of changing anything -'cept if it gets thing closer to original. The automatic takes some getting used to. Just drive it like it was a standard (let off gas) annd shifts smoothly.
F25C9K17624 / WB: 118 / COLOR: R / MODEL: F25C / DATE: 28L / TRANS: X / AXLE: Blank (DSO)* / MAX GVW LBS: 07400 / CERT NET HP: 158 / RPM: 4000 / DSO: 0396
C = 292 2V 9 = 1959. K = Kansas City MO Assembly Plant. 17624 = 1959 Numerical Sequence of Assembly, the trucks specific serial number. 118" Wheelbase. R = The book I use to decode colors is presently in storage, will not be available until 4-21-2017. F250 2WD .. 7,400 lbs. GVWR 28L = Assembled November (L) 28, 1958. X = Ford-O-Matic 3 Speed A/T Rear axle: DSO (Domestic Special Order).* 7,400 lbs. Gross Vehicle Weight Rating. 158 net HP @ 4,000 RPM *When the AXLE code is blank, FoMoCo installed a rear axle that was not an RPO (Regular Production Order) per the request of the original purchaser, making the truck a Domestic Special Order (not "bought off the lot"). The P/S was either dealer installed, or installed by a previous owner. |
(Post 17109650)
F25 = F250.
C = 292 2V 9 = 1959. K = Kansas City MO Assembly Plant. 17624 = 1959 Numerical Sequence of Assembly, the trucks specific serial number. 118" Wheelbase. R = The book I use to decode colors is presently in storage, will not be available until 4-21-2017. F250 2WD .. 7,400 lbs. GVWR 28L = Assembled November (L) 28, 1958. X = Ford-O-Matic 3 Speed A/T Rear axle: DSO (Domestic Special Order).* 7,400 lbs. Gross Vehicle Weight Rating. 158 net HP @ 4,000 RPM *When the AXLE code is blank, FoMoCo installed a rear axle that was not an RPO (Regular Production Order) per the request of the original purchaser, making the truck a Domestic Special Order (not "bought off the lot"). The P/S was either dealer installed, or installed by a previous owner. Thank You! ND Great Information! Is there a way to differentiate between the transmissions, or a good reference source? This one functions as the selector shows. Low is only low; D1 goes from 1-3; D2 goes from 2-3. Cool to know a Dealer did that level of options (p/s). Any way to tell either way? Steering wheel could gave been changed out by an owner I guess - good attention to detail if so! Thanks Again! |
Interesting. I've never heard of power steering but that horn ring is pretty compelling. Do you have a picture of the whole steering wheel? Also interesting is the oil filter canister. I don't recall ever seeing one of those, maybe part of the power steering if there wasn't room for an oil filter on the block.
I would also be curious to know the part number of the back of the horn ring and have it deciphered. |
Originally Posted by willowbilly3
(Post 17110410)
I would also be curious to know the part number of the back of the horn ring and have it deciphered. Thank You WB! Here is a picture of the whole steering wheel (pardon the seat - another battle to come). The canister is indeed the p/s fluid canister - the plumbing beneath it is on the agenda this weekend along with the water pump. Will get the steering wheel off and get that information! Appreciate the help greatly! |
(Post 17110410)
Also interesting is the oil filter canister. It's a remote mounted P/S pump reservoir. I would also be curious to know the part number of the back of the horn ring and have it deciphered. 1959/60 F100/600 Custom Cab w/18" diameter steering wheel / 1959/60 C500/1100 Custom Cab & F700/1100 Custom Cab w/20" diameter steering wheel. |
(Post 17111033)
C0TF-13A805-F .. P/S Horn Ring / Obsolete
that auto with power steering is so rare of a combination.been selling parts for over 30 years,only seen 1 with power steering ,but that horn ring saying power steering,is one rare bird you have there,enjoy what you have,not many have that if any even around anymore,
Originally Posted by sawmaned
(Post 17111698)
Thanks! My neighbor/Wiseman who has been in it that long and knows exactly Everything says the same thing. Glad to get it back on this side of the border (KS/MO)!! |
