1952 F3
Hello,
I'm in the process of working on my first project truck. I don't know don't have a huge knowledge on trucks, but I do know some. I don't know really where to start. As far as the truck goes, it's 1952 F3. The previous owner lost interest in it. He did do a motor and tranny swap, 390 and a 3 speed out of a '68 Fairlane Gt. The rear window is shattered, there is someone nearby that have the glass out of a 51 F2. Would it fit? https://cimg2.ibsrv.net/gimg/www.for...152f5a86d9.jpg https://cimg3.ibsrv.net/gimg/www.for...626f4679c0.jpg https://cimg4.ibsrv.net/gimg/www.for...8312257c02.jpg https://cimg5.ibsrv.net/gimg/www.for...dde1f5f24e.jpg |
Welcome. Glad to have another F-3 join the group. I see from your profile that you live in Illinois. What area? I'm in the Spfld area. Your glass will swap just fine. You'll probably want to put in new rubber with it. Stu
Originally Posted by truckdog62563
(Post 17073242)
Congrats on that! It looks great....actually looks pretty solid..if you plan on driving it make sure it safe
Originally Posted by Jafo56
(Post 17073262)
Welcome from Maine.
That is a nice solid truck there. The F-3 specific body parts that aren't available new and hard to find are in pretty good shape on yours. Nearly everything else can be found as new reproduction parts since the F1 shares quite a few parts. Looks like you have an extra tailgate. Nice...those are one of the hardest parts to find. You might be able to trade that with a member here that has something else you need. Tom |
Originally Posted by pineconeford
(Post 17073267)
Welcome from Maine.
As for brakes...the front ones could be 12" and shoes and cylinders aren't hard to find. The rears could be 14" and it gets a little trickier to find parts. But not impossible. Just need to measure and carefully examine what you have to match them up with new parts. Your master cylinder has a larger bore than the 1/2 ton and you have larger diameter brake lines.
Upgrades to whole brake system can be done - for example convert to disc in the front and still keep the 8-lug pattern. Lots of advice and information here in the archives. Search for '8-lug' and many threads will appear that will cover F2 and F3 wheels/brakes/rear differential topics. good luck and thanks for posting pictures. We like that! . |
Originally Posted by Nick Olsen
(Post 17073277)
.... wasn't aware that tailgates were a rare find. One of them isn't in the best of shape though.
Welders/fabricators can make them look good and straight again. It's harder to make a reproduction F1 tailgate ever work for someone who is missing a tailgate. Like stretching a queen size sheet to fit a king sized bed. :D . |
Stock rear brakes in 1952 are Bendix 12". The 14" Lockheeds went away mid year 1951. If the p.o. swapped in the 390 and 3 speed he might have swapped the rear end too. If not a 1967 to 1972 F-250 Dana 60 is an easy swap. Stu
(Post 17073283)
(Post 17073295)
Any shape F2/F3 tailgate is still a good thing.
(Post 17073277)
Thanks! I thought that they shared a few things. ....
Might be easier to mention what isn't the same with a 1/2 ton: Frame, all four fenders, bed, tailgate, brakes, steering box, running boards, rear leaf springs, rear differential. Other than that, you can pick up some parts catalogs (LMC Truck, Dennis Carpenter for example) and go nuts fitting up that truck with anything it needs that you want to buy new. |
(Post 17073300)
(Post 17073328)
Everything in and on the cab is the same for all 51/52 models.
Might be easier to mention what isn't the same with a 1/2 ton: Frame, all four fenders, bed, tailgate, brakes, steering box, running boards, rear leaf springs, rear differential. |
