2003 Ford Ranger extended cab rear door pannel removal?
I just purchased a 2003 for ranger extended cab fx4 and wanted to put nicer speakers in the rear doors but for the life of me canot get the rear door pannels off... how do they come off?
Hello chronos, welcome to Ford Truck Enthusisasts!
This thread might help....look for the link for removing rear door panels on a Ranger: Ranger Audio Tech Articles Good luck! Let us know how it sounds when you are done. |
thanks alot that site had exactly what i was looking for its nice to finaly find somewhere with instructions and pictures now no worrying about breaking the door:) thanks alot
You're welcome. :)
Tempe, the guy who put thogether that Audio Tech Articles page, is a wiz at audio-related stuff and a very helpful member here at FTE! :cool: |
Any one have the new link to the tech article on Ranger Audio?
95+ Ranger Front Door Panel Removal Tutorial
I've had some other people tell that they couldn't access Tempe's rear door removal tutorial at TRS ...so I converted the html page into a PDF file which should now be accessible: 95+ Ranger Rear Door Panel Removal Tutorial |
I took my door panels off last week to do the same. BE CAREFUL. I broke one clip on each side. One side actually broke the piece on the panel itself so it's toast. They are a nightmare to get off. Once off, you should remove all the clips still in the door, and reattach them to the panel. That will make the panel easier to pop back on. If I ever need to get to the speakers again, I'm thinking of cutting the panel around the speakers and making my own access hole there. It's ridiculous how Ford designed this thing on the 4-door models.
WX, what did you break, the panel slides up it doesn't have the pins like the old ones did.
Mine had 12 clips. I call them "rivets". They are the push-in type and are a NIGHTMARE to get out. I ended up using pliers and a screwdriver after I noticed blood on my fingers. It's nuts.
Duh, I missed that you were doing the rear doors.
Oh, yeah. :) OK, I thought maybe the ones built at the other assembly plant were different or something. I was about to get jealous. ;)
First time to the forum, and everything here looks great I just bought a 99 Ranger XLT 4.0l V6, and I'd like to replace the front and rear factory speakers. The link for the front panel removal is great and a big help, however both the links for Tempe's rear door removal tutorial at TRS and the pdf that rockledge posted are bad. Can anyone repost the pdf or fill me in on how to do this?
The rear doors are insanely hard to remove. Not sure why its necessary to have those plastic rivet things every 6 inches... I guess if you have a panel tool it would make things a little easier. I think i just ended up pulling on the panel near where i could tell a clip was.
Try this link: Rear Door Panel Removal for Ford Rangers
That link works great, thanks!
