Rear Seat Belt Buckle Installation
Hello all! I'm new to this thread. I just bought my 2004 Ford Escape here two weeks ago and I noticed something that I didn't notice until now. I went to go take my sister over to her concert tonight and when she went to go buckle up in the back, there were no female ends for the seat belt on both sides. Knowing that she's under 16 and I live in New York, if I was to get pulled over with her in the back, that would be a serious ticket.
So I was just wondering, how do I install them? Thank you all in advance! |
Sure they haven't slipped under the back seat base? Seems an odd thing to remove - but if they have been removed there will be mounting holes under the rear seat into which they bolt, it will be obvious if you pulled the seat base forward.
TBH if they have been removed I'd go back to the seller, its likely it was illegal to remove them in the first place... |
I actually checked and they're completely gone. I saw where they bolt into place and everything too. The guy I bought it from had no idea that they were gone, as he was originally going to use that one for parts (which is a shame too. The body on it is in nice shape and it runs beautifully.). Thankfully there's a junk yard close to where I live so I can get them easily.
So all I have to do is just put the seat down and unbolt them then when I go to remove them? |
Originally Posted by PhoenixLaw92
(Post 17038707)
Alright then! Thank you so much for the help!
(Post 17038779)
I'm trying to remember if my '02 had "keyed" receivers for the rear seat belts.
I seem to remember riding in the back once when my son was learning to drive and finding the left side seat belt not fitting into the "center" receiver.... You should be OK, but you'll need to test fit them before mounting to ensure they are in the correct position if my recollection is correct. |
