Audio control in steering wheel - F350?
Hey guys just received Part #SW-6772 that will go on the right side of my steering wheel in my 2011 F-350 XLT.
The switch is the one we use to control the audio (radio, cd, etc) remotely. This truck didn't come with the switch installed. I want to use the switch to hopefully run a Pioneer Smartphone Receiver installed in place of my factory radio. Question: What wiring harness is used to connect from the switch I just bought (#SW-6772) to the radio? It must be a Motorcraft "standard" harness? Thanks!! |
Bueller? Anyone lol?
Have you removed the plastic cover to add the switch yet? Ford sometimes uses the same wiring harness for both XLT and lariat. If the wires are there to connect up the switch, then chances are it will work with your new head unit. BTW, I recommend having that done by a pro. my .02
Originally Posted by RailDawg
(Post 16955596)
The switch is the one we use to control the audio (radio, cd, etc) remotely. This truck didn't come with the switch installed. I want to use the switch to hopefully run a Pioneer Smartphone Receiver installed in place of my factory radio. Question: What wiring harness is used to connect from the switch I just bought (#SW-6772) to the radio? It must be a Motorcraft "standard" harness? Thanks!! Adding Audio Switch to a 2011 Expedition XL Ford Expedition Forum |
