C/E Light on. Purge Canister Solenoid Code
Hey guys,
Been a member here for years. Had a bunch of F250's and a nice F150. Now I have two Broncos. Always had great responses and help from this site. I just bought a 96 Bronco xlt 5.0 last week. It runs like a champ, is super clean. I searched the forums and didn't find what I was looking for... I have two issues though: 1. One simple one is the o/d light is blinking and shuts off as I drive. No tranny issues at all, shifts nice. 2. I have a Check Engine light on. I pulled the code and only got one. It was a Purge code. I went to Ford and bought a new gas cap hoping it might be that. It wasn't as I reset and it came back on after maybe 4 miles. I bought the new black plastic purge solenoid canister for $90 from Advanced Auto, changed it out and found one small hard vacuum line going to the bottom of it was broken, so I fixed that and put the new purge canister solenoid on. I pulled the positive cable off the battery to reset the computer. I drove to Tractor supply which is about 5 miles from my house, shut the truck off, came back out, turned the truck on and the light came back. I need help with this one. I want to get the truck inspected as a I have a 10 day temp tag for inspection. This is the only code the truck comes up with. Thanks in advance, Anthony |
I pulled the codes again and got a p0443 evaporative emission system purge control valve circuit and I got a p1351 ignition diagnostic monitor input circuit.
I tried changing out the purge solenoid and the check engine light came on about 10 min after I cleared it. I am going to swap out my egr valve today to see if that's the culprit as mine looks like its rusted pretty bad. |
Originally Posted by MonroeHandyMan
(Post 16955775)
Just to be clear the 1996 F150/Bronco uses a Vapor Management Valve to control fuel vapors. It's not the same as the older Canister Purge (CANP) solenoid.
(Post 16955775)
(Post 16955775)
