Clips for F1 trim
I have heard that Restoration Specialties has these spring clips have you guys found them any other places
https://cimg0.ibsrv.net/gimg/www.for...fae98e7e91.jpg Are these what you are using? |
Sorry my friend I am very pressed for time at the moment, but here are a couple links I found on google under trim clips for 48 F1. I hope it helps, gotta go1948-1979 V8 Ford Truck Clips And Clip Kits Clips And Clip Kits - Macs Auto Parts https://www.bobdrake.com/Categories2.aspx?Id=4852hood
Thanks jimmy but I think I need a part number
I'm back Roy, sorry I had to post and run like that . FYI, I do have the "CD" 1948-56 Ford Truck Master Parts Catalog. If you need it, PM me your address and I will mail it to you. You can keep it as long as you need. I haven't had much luck finding the clips so far on it, but you may do better since Im dyslexic.
1 Attachment(s)
I finally found the page and figured out how to scan and transfer it, I'm sorry it took so long, I not real computer savvy . I hope this one will help. "ROCKING ON" the FTE way. :-X0A6
Clip for 16720 mouldings shown in pic ^ as 358158-S / Clip for 16956 mouldings shown in pic ^ as 352191-S
The actual part numbers are: 352191-S3 = CARPENTER NOS OBSOLETE PARTS in Concord NC has 141 = 800-476-9653. --------------------------------------------------------------------------------------- 358158-S3 = NOS PARTS LTD in Waxahachie TX has 4 = 972-937-2201. CARPENTER NOS OBSOLETE PARTS has 162. :( Parts catalog pics of standard (aka hardware) parts may not show the complete suffix. |
Thanks jimmy I do appreciate you and Number Dummy
Dennis carpenter sells some with the trim not separate I think I may have found them at Restoration Specialties I'll post their PN after I see if they work:-jammin |
FTE won't let me give you two any reps
I found them at Midwest Early Ford, page 59 in the catalog I have (April, 2015). The were just like the original and worked fine.
Are washers or shim washers at the hinge
the hoods on both my trucks were not on the hinges and Jim exploded view does not show any https://cimg1.ibsrv.net/gimg/www.for...68162b0bed.jpg |
1 Attachment(s)
Originally Posted by schoo
(Post 16879663)
Are washers or shim washers at the hinge?
The hoods on both my trucks were not on the hinges and Jim exploded view does not show any. 16796-7 hood hinges and attaching parts: |
I read that ND post as no 48-52 and yes 53-56?
To be clear the place I'm talking about https://cimg7.ibsrv.net/gimg/www.for...4b5876a18c.jpg |
I'm not use to the hood at all
https://cimg9.ibsrv.net/gimg/www.for...3ecbc2f134.jpg |
Suggest that you message 51panelman. Ilya has been collecting these parts for years and I think has the latest sources for clips. Also you can search this forum using the term "trim clips" and you will find lots of sources. The last that I saw was one recommended by AxRacer Restoration Specialties & Supply, Inc. | Windber, PA 15963
His post was https://www.ford-trucks.com/forums/1...l#post11698857 |
Originally Posted by petemcl
(Post 16881989)
His post was https://www.ford-trucks.com/forums/1...l#post11698857 I'll post PN after I know they work |
