390 Hydraulic lifter help
Currently researching and collecting parts for my 390 build and for most part things are wrapping up quite nicely. But I do have a question in regards to the choice of lifters. I know I will be using hydraulic flat tapped lifters with non adjustable rockers. I am looking into a Lunati P/N: 10330701 cam, but there is also a choice of purchasing a kit with it, which comes with lifters. I do have stock lifters from my old block and they are in good condition. Lunati claims their lifters are superior and weight less. Crane offers anti pump lifters CRN-99281-16.
I have three choices from which to chose. If anyone could give me some pointers on choosing lifters it would be greatly appreciated. Nick |
used lift off another cam or reinstalled out of order on a cam can lead to destruction of a lobe. when lifters break into a cam they need to be keep in order for that cam. when replacing a cam the lifters should also be replaced with new ones.
My opinion is to always use new lifters with a new cam. There is a 20 minute break-in procedure that the two need to mate together. Why mate lifters with a previous wear pattern into a new cam. Recipe for disaster in my opinion.
Originally Posted by 1mouse3
(Post 16818051)
Originally Posted by Krewat
(Post 16820232)
This. NEVER EVER reuse lifters from one cam on another.
Never use old lifters on a new cam.
I normally get the lifters from the same company I get the cam from. Ran a set of Crane anti pump up lifters years ago, they never floated but I did have some issues with lifter peck using light grade oil (10W30) after a few hundred miles. |
You need this:
Voodoo Hydraulic Flat Tappet Cam & Lifter Kit - Ford 352 - 428 256/262 - Lunati Power That's the cam and lifters from Lunati. |
Originally Posted by abyars111
(Post 16821526)
You need this:
Voodoo Hydraulic Flat Tappet Cam & Lifter Kit - Ford 352 - 428 256/262 - Lunati Power That's the cam and lifters from Lunati. Nick |
Originally Posted by Nick-1973-ford
(Post 16831010)
Yes, I was eying this piece for a while. Lunati reps also recommended 73815K8 spring kit for this cam. Any thoughts about it?
Nick |
get the full kit , less chances of problems .
I got the full kit when I did mine |
Yes you need the springs to go with that cam, factory springs will coil bind at around .500 lift, that cam has .524 lift, like other's have said get the complete kit.
