New WARN Ascent Bumpers for '17 Super Duty
2 Attachment(s)
Attachment 164210
Warn has now introduced our line of Ascent Front and Rear bumpers for the all-new 2017 Ford Super Duty. The front bumper will accommodate WARN winches up to 12,000 lb. capacities, including the ZEON and ZEON Platinum. They have four ports for lights (sold separately), welded eyelets for shackles, and will not interfere with the front camera if so equipped. The angled design sits high to maintain maximum ground clearance and approach angle, and the 11-gauge steel construction with black powdercoated finish will withstand all sorts of harsh conditions. Attachment 164211 The rear bumpers are also made from 11-gauge steel and wear a black powdercoating. They have ports for lights (sold separately), corner steps for easy bed access, and will accommodate back-up sensors. Both fronts and rears are designed to accommodate oversized tires, provide maximum off-road performance/clearance, and are easy to install. You can learn more at https://www.warn.com/truck/mounting-...nt_systems.jsp. - Andy |
