V10 won't start when cold
Hi,
I tried posting this in the V10 forum, but no one replied, so I thought I'd expand my audience. I'm having a problem with starting the V10 in my 99 E350 cube van. It refuses to start when cold unless I stick my finger in the idle air control valve and force it shut, or use starting fluid, or a combination of both. Once I do get it started, it will die if I touch the throttle, but once warmed up, it runs fine. I have replaced the IAC, the cylinder head temperature sensor, the fuel filter and fuel pump, and cleaned the MAF. My code reader shows no codes, and like I say once warmed up it will run fine and restart no problem. I'm kind of out of ideas on this one, anyone have any? Thanks, |
What signals the IAC valve to close? That is where I would be looking. Is it vacuum operated? A bad vacuum line?
