Pair of 05-07 Super Duty Headlight Assemblies
Have a pair of used ford headlight assemblies which I originally purchased locally for my Excursion, but I did not end up using them. These are NOT a direct fit for the Excursion, and require cutting the header panel and a wiring connector conversion. Check this site for information regarding what is required for the Excursion conversion.
These are a direct fit for 05-07 Super Duty F250 and F350 SD Trucks. Ford factory OEM part, slightly used. Not aftermarket. Lens is clear and sold as is, I have not buffed them out or done anything to them. Some wear, but lens is clear and just needs a good polishing. Mounting points look good, please verify by checking the pictures. Very small piece of plastic missing from one side at the very bottom, see picture for full clarity. Buyer to pay actual shipping charges, no handling charges. It is packed securely in a larger box with plenty of padding. Sorry sold as is, no returns. Pick up locally at no cost. 6C3Z-13008-AB 6C3Z-13008-BB |
