Stock "53 Steering Box Questions
I attempted to adjust the stock steering box on my "53 F-100. I followed the instructions found in the Shop Service Manual for the truck. Per the manual, I was able to measure (within ounces) the amount of force it took to get the steering wheel to move by adapting my wife's Weight Watchers digital scale. (If anyone is interested in how this was done, just ask.) I added and removed gasket/shims to the bottom plate to achieve the recommended resistance. I tightened up the adjusting screw on the side to take all the play out of the sector shaft. At this point I ran into both a problem and a question. The problem is the first 1/4" (approx) of threads inside the locking nut for the sector shaft adjuster are stripped. The adjuster is screwed so far in that there are not many threads in the nut engaging the screw. I do not see this part available in the typical after parts catalogs. And, like similar problems I've had, I do not even know what this particular kind of nut is called. I suppose it's some sort of acorn nut or cap nut. If anyone can direct me to a source it would be appreciated. And the question I have is: what keeps the gear oil from dripping out of the box around this same sector shaft adjusting screw? I see no seal or washer in the exploded view of the steering box. I filled the box up to the top of the filler opening, but the drip at the adjuster screw slowly drains out over half of it. Is the box supposed to be full? Do they ever not leak?
Since the screw is next to flush (a sign of how worn your gear is) I wouldn't be too concerned about a slow drip. Sounds as though it's time to begin saving some nickels for a rebuild. Not having crawled under to look I'm going to guess the nut is a common thread. Not sure why there would be an acorn nut on it as you wouldn't be able to hold the screw in place while tightening it. If I were you, what I might try is remove the nut, make your adjustment then stretch a piece of a latex glove over the screw threads and install the nut.
In days gone by many peeps would pack the gear with grease, instead of using oil, in order to 'fix' the seepage. That's a no - no, the gear needs oil to be properly lubricated. Besides being a tad undersized for the job, my thoughts are the lack of, or improper lube used, is the reason for most of the gears being typically worn out. Back then checking the lube in the gear was considered a normal oil change procedure - just as checking the trans and diff. And periodic adjustments reduced the wear rate. Think of driving a nail with the hammer sitting directly on the nail - not much happens. But once some clearance is gained you can begin pounding the heck out of it. Same thing happens when any clearance opens beyond spec. |
1 Attachment(s)
Originally Posted by CBeav
(Post 16596124)
In days gone by many peeps would pack the gear with grease, instead of using oil, in order to 'fix' the seepage. That's a no - no, the gear needs oil to be properly lubricated. :-huh
So I have to ask, are you sure that 1953/56 trucks didn't use steering gear grease, too? Pic from 1948/56 truck catalog: 2nd row, steering gear grease is 3rd from the right. |
There are different kinds of grease, of course. Therein the confusion.
Steering gearboxes get the equivalent of NGLI #00 aka "self leveling" grease. NGLI #2, on the other hand, is what most people are familiar with, a lithium based chassis grease, which should NOT be used in a gearbox. Another equivalent is "corn head" or "pickerhead" spindle grease available at just about any farm implement store. John Deere makes a good one, I'm sure there are others. 90 wt. will work but it usually leaks on used or old gearboxes. http://www.tractorsupply.com/tsc/pro...ndle-grease-00 |
(Post 16596124)
Originally Posted by Tedster9
(Post 16596451)
Another equivalent is "corn head" or "pickerhead" spindle grease available at just about any farm implement store. John Deere makes a good one, I'm sure there are others. 90 wt. will work but it usually leaks on used or old gearboxes. Super S Cotton Picker Spindle Grease 00 - For Life Out Here |
I'll look into the "corn head" grease. I don't have time to rebuild the box until next spring. From now till then, I don't expect to put on more than a few hundred miles. So, a temporary solution sounds good.
I know that this is not what the book says, but I have chosen to use a mixture of 3/4-90wt and 1/4 the old STP. I have no leaks and am sure everything gets lubricated.??????? That reminds me it's probably time to change the oil in it. A close check for metal in what I drain should tell me how well my concoction worked.
I'm using a manual gearbox full of STP, heard about in a similar discussion to the one here. I've since read though, STP is not an oil and has no lubrication properties.
Best to use the proper lube, it's not hard to find or expensive. |
The important thing is to keep whatever lubrication you might choose to use, high enough to keep the top worm shaft bearing lubricated. Top it off periodically if it leaks. If you're using something like chassis lub, pack it in tightly once in a while.
Well, to be totally honest I used Lucas Hub Oil in mine. I know my box also has a short future and this was handy, so...
(Post 16597687)
Well I looked up the MSDS for STP. It *is* oil, or mostly 90% anyway. Nasty stuff, I'd never put it in a crankcase, stuff is like glue. Seems to work fine as a manual gearbox lube though.
It may be o.k. for the bearings and gears but will make shifting more difficult as it will interfere with the blocking rings being able to slow down the gears.
Manual steering gearbox, sorry if that wasn't clear. I wouldn't use it in a transmission.
