Not turning off??
My 95 ford bronco turns on and runs great, However when I turn the key to the off position my bronco won't turn off. The key just loosly turns. I had replaced the lock cylinder and is still doing the same thing. What else might be the problem?
The ignition switch.Or the actuating rod
might be the solenoid too. check them connections.
Originally Posted by ManfredVonRichtofen
(Post 16592143)
If you're referring to either the solenoid in the fender or the one in the starter, neither will cause this. Those could cause the starter to remain engaged, and you would notice right away.
Originally Posted by Encho
(Post 16605779)
