Looking for material for sheet metal...
I cannot remember where I saw this, but I swore there is a liquid (not spray but brush/roll on) where you have some rusted areas of sheet metal and this will build up around it, solidify it, and potentially close the hole/holes or any pitted areas. I thought is was black and even could sand it a little after drying for a bit.
This sound familiar as I do not want to go the bondo route (not for this at least) and welding will take way too long to fix. Thanks! Ed |
Never heard of a liquid but I have used Flame Spray, Inc on a few occasions for this sort of build up.
Hi Ed, Are you talking about POR-15
One brand is SEM Rust-mort, it can be brushed, rolled or sprayed. You pica you poison.
The Eastwood rust converter turn black. It is nice as it is water cleanup. On heavily pitted areas I have used that, then fillable primer and then a thin coat of Rage Gold lightweight filler. The Rage is thin and spread out easily. Easy to sand down. I suppose that I could skip the fillable primer but I think that it helps with the bond.
