B99 in a 6.7?
Has anyone run B99 Bio-Diesel in their 6.7?
Any problems with it? |
Emissions will not tolerate it.
Originally Posted by senix
(Post 16477584)
Now it's possible the newer regen strategies may not like it or it may not help lengthen the distances between regens any more. Really, the sweet spot is B20 for a variety of reasons. This was using regular Transtesterfied Soy Bean Oil stock for Bio - it's what the local person sold near me in Miami. The new Hydrogen Cracked stuff that's pretty much only in California I don't have experience at all with - and that is supposed to be able to be burned at the B99 level without any issues too. CAVEATS There are more things to consider when running bio - even at the B20 level... Anything above B20 and your are risking warranty denial for engine/fuel system problems. |
Cool weather ......bio doesn't like
That is why I don't run Bio, at all, up here. Shouldn't be all that much longer that #2, summer fuel disappears here.
I have seen B2 (not 20) up in Michigan at Pilot Stations though... |
I've seen B20 in the summer around here. Winter none.
Do you ever run it? I like to, when I can. Just haven't been able since I moved in 2014...
I have in older truck. Smoothed out the 6.0 but limited availability. So just went to reg Dino fuel.
My 6.0 went it's whole life on B99... But then the seller went belly-up.
I believe bio also has a tendency to retain more water than regular diesel, which is a no-no on the 6.7.
Any water from any source in the fuel is a no-no in an modern diesel. Yes, Bio is more hydroscopic than regular diesel fuel. Never ran into that issue and know plenty of people that have put tens of thousands of miles on Bio without issues.
There are other issues with B99, like lower power and in older diesels it degrades rubber fuel lines, ones not made out of Viton (sp?). It really cleans the tank and lines of sludge so it can clog fuel filters. Since I can't get it and really run it due to the climate I live in, I am not following it anymore. I only ran commercially made, quality controlled, ASTM certified bio-diesel. No backyard brew. Because of the cleaning qualities of it, I liked running a tank of B99 through right before a fuel filter change. |
