Manual transmissions
So the search function for the site doesnt work with my phone. I am wondering which tranny i have. The truck is an 85 f250 4x4. It is a 4 speed with granny first. I can post pictures later if needed. Thanks!
T18
-Enjoy fh : )_~ |
The other thing that can help you is this link from Gary
Certification Label - ???Gary's Garagemahal Dave ---- |
My 86 F250 had a new process 4-speed in it.
Only way to know for sure is to crawl under the truck and look. |
Originally Posted by cliffordingles
(Post 16390831)
I am wondering which tranny i have. The truck is an 85 F250 4x4.
It is a 4 speed with granny first. This bit of info narrows it down to 3 different 4 speeds! :-X04 It could be any of the following: A = New Process 435 4 Speed / F = Borg Warner T-18 4 Speed / P = Borg Warner T-19 4 Speed. T-18/T-19 = The shift lever retainer cap (8MTH-7220) threads off/on. New Process 435: The shift lever retainer cap (B8T-7220-D) has two notches, is retained to the shift tower with two pins. This cap must be pressed down by hand and held down while turning it counterclockwise to remove it. Some unknowing people use pliers to remove it, which tears out one or both of the notches. Not pleasant! |
Thank you for all the replys!!!
