2001 f250 5.4L
Hello all.
So I've come across a small problem with my truck. Every morning when I go to start it. It won't start it cranks but won't start I turn key back and try 2nd time to start and I fires right up I've changed fuel filter, cleaned maf sensor plugs checked for vacuum leaks o2 sensors It's like it's starving for fuel I don't think it's the fuel pump issue Anyone have this issue? |
Suggestion : try this, depress gas pedal 1/2 way and then crank , if it starts it is IAC (idle air control valve ) , you can clean it .
If it is not IAC , buy/borrow (Auto Zone ,etc) a fuel pressure tester and check fuel pressures at fuel rail . Good luck |
Iac
Thx eh I will try as soon as my father in law returns my truck with a full tank of 94 octane.
This trucks love the good gas! |
