Vent window frame for an 81 F100 question
You guys were a lot of help with my question on the 300 six motor plate and showed I should not assume anything.
I will need a left side vent window frame. The part held to the door with 2 Phillip up screws at the top front and 1 bolt behind the door panel. Question is of the years I would be looking for to use on my 81 F100 project? Would it be 80-86 or other years that could also be used? While on the vent window question, the bottom pivot on both of mine are frozen and looks like it broke the rivets off. I have not looked too close but it looks like if I could get it to free up I could maybe use new rivets or tack weld it to hold it in place. If this isnot so then I would need both side vent frames and the replacements would need to be free to pivot. Oh I know I can buy new but at $170 ea new is not going to happen anytime soon. Thanks Dave ---- |
I would go ahead and try to free it up and see what happens.
The catalog shows the same vent window used 1980-89 for the F-series and Broncos. And, the "89" is just because that's as far as the catalog goes. IOW, I don't know about into the 90's.
On the pivot, I would think tack welding it would work. But I haven't looked - although I will later. |
I put up a web page to answer your question - for the next person: Windows - ???Gary's Garagemahal.
Have 4 of them you can have here in Texas if you are close. All you have to do is come grab them.
Thanks guys maybe tomorrow I will look into freeing up the other side to see where it goes if I can work with it or need another. Heck I need 1 why not both right?
Gary, did not know 21408 was not part of the bar 22296. You can get the vent frame & bar or just the bar but not just the vent frame if I read it right. 80ford, thanks for the offer sorry to say I am not close, I am near Raleigh, NC. For a little coin would you maybe ship to 27501? If not I do under stand Dave ---- |
Dave - That's true new, but from a salvage - or your parts truck.....
(Post 16381908)
Then again if it had doors don't know if they would be any good? http://cars.grantskingdom.com/var/re...219_124941.jpg When the banker (wife) says we have a few bucks to spend on the project (unless a too good of a deal comes by) buying parts is on hold. Did I tell you it needs a lot of parts? Dave ---- |
Ok, I understand.
