window sizes
Am working on a 52 f1 am going to get Windows cut ,I made a templet of the back Wind i need to no how much bigger then the hold mill i need to cut it.If any one has a back class can you mesure it that be good help thanks .Will also need the same for the front window .
Also going to do the door widow whit no vent i saw a few post but will need more info if any one has that can help . |
Are you aware that new pre-cut window glass (tinted and non-tinted) is available from many sources?
Yep but where am shipping is a killer more then the window it self .I have a place in town that cut them no problem and not to pricy also
Ok, my apologies. Didn't know that. Would be a big help to update your profile to show your location or whereabouts.
For my 52 I bought mine from Vintage Glass (Ball's Rod and custom).
My glass company tried to install them and the front & rear were too big. Edges were not smooth and some of the glass did not follow the contour of the old glass. TractormanBill |
Do you have the remnants of your old window that they could copy? I took my two cracked door windows to Safelite to make new ones.
Originally Posted by abe
(Post 16291966)
TractormanBill |
any way you can mesure them for me
I don't know how I could measure it to where it would do you any good.
TractormanBill |
you can musure the hight of the window in the middle of the window and same thing for the Wight of the window.Am trying to see how much i have to cut so it fit in the rubber good
Originally Posted by coupman35
(Post 16292800)
TractormanBill |
If window is out of truck lay it on top of brown paper and trace with marker.
You can mail the paper and give whole thing to glass place. Let them cut it out. |
I wish i had the window but i dont
Just have your glass shop come out and make their own pattern, then cut and install the glass. Or you install it.
they wont do that they have to much work ,i can do it am just trying to make shure i have the right size
