Tight-Bolthole |
05-05-2016 08:39 PM |
EFI Flat tappet to Carb'd Roller Conversion
I'm spicing up the 7.5L in my F350. I have a fresh set of CV9E heads w/ worked exhaust ports. Eagle 545 rotating assembly. Stealth intake, Quick fuel 750cfm E85 Carb & some fuel pump mods. I'm going with a Davis Unified HEI distributor for the spark.
I'm looking at This Comp Cam Roller Conversion kit. I have heard some negative things about converting a 460 to roller for street use?? Something about not being oiled properly. Also, I don't want to loose my low end power. Any thoughts?:oval
