does your truck makes it's spot?
My wife is getting tired of my truck MARKING its spot( not makes) . She said the pile of rust is getting larger every day......
mine marks its spot with oil and a bit of fuel :-roll
Mine never did till I started with the stupid blow by.
Not really. About once a month it might leave a quarter sized spot in the garage. I wipe it up and it is fine for another month
Mine does... and will continue to until I get that dang $300 dipstick adapter.
A drop from the road draft tube and ocassionally some from the turbo pedestal (until I instal the Riff-Raff delete pedestal) then, just the road draft tube....
... a little oil keeps it moist underneath.....
That's what she said....
Man, my truck is like an alpha dog ever since I got it, seems like it marks everything. First it was a oil leak from the drain plug washer, then an oil leak from a loose valve cover, then a coolant leak, then another coolant leak from the water pump crapping out, and now an axle seal leak..... its endless.
Compared to a Class 8 big truck, none of them really leak all that bad.
I get a kick out of going to Auto Zone or any discount parts place.... You can always tell the customer parking places by the oil and goo on the pavement out front.....lol |
I've got to admit that I've contributed to those stains many times lol
My junk leaves no trace! Well other than soot if Ina hurry lol
Originally Posted by fordman67
(Post 16207318)
Actually, I park mine on gravel so any leaks attribute to dust control.
between my hydraulic tank, seeping front axle seals, possible oil pan gasket, and the dip stick adapter. Mine plays the role of dominate male in walla walla Washington. Dust control, that what I use mine for too. Ha ha ha
