5 bolt auto hubs to manual conversion?
My truck is a 1994 F150 with automatic locking hubs, these hubs have 5 bolts holding the hub on.
I want to replace these with manual locking hubs. Do I need a conversion kit to do this or is the conversion kit just to convert from auto hubs with 3 bolts? |
Can't say for sure on your Dana 44 hubs, but the Dana 50 hubs on an 94 F250 that I have had the 5 screw auto hubs and while everyone even service at Mile Marker said that a conversion kit was required, it had the same internal nuts as was in the conversion kit that I ordered.
Pretty sure the 5-bolt have the proper spindle nuts, so you won't need the conversion.
It depends on the manufacturer of the hub. Some such as WARN require a conversion kit, others do not. I replaced my auto hubs with Superwinch hubs 18 years ago and they have performed flawlessly. Direct swap
All you need is a set of Warn (or insert your mfg of choice here) hubs for your Dana 44. Nothing else is needed.
It is literally a 10 minute job. |
Thanks for the replies. I have ordered Milemarker 104 premium hubs. I will report back with how it goes.
Originally Posted by animator
(Post 16200417)
Originally Posted by Nothing Special
(Post 16201544)
At least some auto hubs require a different spindle nut. And that spindle nut gets in the way of some manual hubs. So swapping from autos to manuals isn't always quite that simple. It's not a lot worse, just swapping the spindle nuts, which are right behind the locking hubs, so nothing else needs to be done. But a lot of people will choose to relube the wheel bearings since they're in to that point already.
The 3 bolt auto hubs need the spindle nut conversion - these show up in mid-94 and later Bronco/F150's. They have the proprietary spindle nut that is held in place with a keyed washer. Just an FYI for anyone who searches for this later. http://www.supermotors.net/registry/2742/12739 |
Originally Posted by TC-Countryboy
(Post 16197528)
Originally Posted by Crossriverfarms
(Post 20685245)
Which conversion kit did you get? Was it still a 5 screw?
