Junkyard contour bumper project
Original plan was to get some junkyard bronco brackets to modify and a new chrome contour bumper from Dennis Carpenter Ford. Well the bumper attached to these brackets was in darn good shape and I got the setup for $50 so why not?
http://i1214.photobucket.com/albums/...127_150901.jpg http://i1214.photobucket.com/albums/...127_150915.jpg Somebody had welded part of a hitch to the bottom and used one of the lamp holes for a trailer plug. I had originally planned to shave the top carriage bolts but after looking at how they key to the bumper bracket slot decided it was not a good idea. Here it is all slicked up with some gloss black powdercoat. Where I filled the license lamp holes is still a bit low. If I had a do-over I would have filled with some JB weld http://i1214.photobucket.com/albums/...314_113503.jpg http://i1214.photobucket.com/albums/...316_115307.jpg |
Modifying the bronco brackets. Originally I thought I wouldn't be re-using any of the holes so I cut the end of the bracket off straight. If you want the bumper tucked tight to the body (a little over a finger width) you will re-usle the hole on my splice.
Most of the weld has to be ground flush to accommodate the support bracket, so after tacking and fitting the brackets I ground a nice channel with my die grinder for a fillet weld. http://i1214.photobucket.com/albums/...302_141013.jpg http://i1214.photobucket.com/albums/...302_154755.jpg Prepping lamp holes for the washer. Washer warped a good bit. A better way would be to cut a piece of 1/8" plate with a hole saw. http://i1214.photobucket.com/albums/...307_103933.jpg http://i1214.photobucket.com/albums/...307_103942.jpg http://i1214.photobucket.com/albums/...307_110700.jpg http://i1214.photobucket.com/albums/...307_110705.jpg http://i1214.photobucket.com/albums/...307_140542.jpg http://i1214.photobucket.com/albums/...315_165020.jpg |
Originally Posted by hivoltj
(Post 16134792)
Ok, this is try number 3 for this thread so I'm gonna picture dump then I'll come back and fill in details
http://i1214.photobucket.com/albums/...127_150901.jpg http://i1214.photobucket.com/albums/...127_150915.jpg http://i1214.photobucket.com/albums/...314_113503.jpg http://i1214.photobucket.com/albums/...316_115307.jpg |
I'll post up with my lighting solution tonight
The rear bumper turned out really nice. :-X22
....the potential downside is, you MAY have created a cop magnet by deleting the license plate lamps. Excerpt from the Montana motor vehicle laws: License Plate Lamp "Vehicles manufactured after January 1, 1956, must emit white light to illuminate the license plate for 50 feet to the rear. License plate lighting that is not original manufacturer’s equipment is prohibited." In Arkansas, law officials like the excuse to pull people over because their 'license plate lights were out.' I have a black contour bumper on my '69 F100 Ranger. The bumper, brackets, bolts and license plate lamps came from NPD. https://cimg1.ibsrv.net/gimg/www.for...af3cb1b71c.jpg |
Turned out great. Can't wait to see the lights.
Originally Posted by ultraranger
(Post 16135648)
....the potential downside is, you MAY have created a cop magnet by deleting the license plate lamps. Excerpt from the Montana motor vehicle laws: License Plate Lamp "Vehicles manufactured after January 1, 1956, must emit white light to illuminate the license plate for 50 feet to the rear. License plate lighting that is not original manufacturer’s equipment is prohibited." In Arkansas, law officials like the excuse to pull people over because their 'license plate lights were out.' I have a black contour bumper on my '69 F100 Ranger. The bumper, brackets, bolts and license plate lamps came from NPD. https://cimg1.ibsrv.net/gimg/www.for...af3cb1b71c.jpg If only you knew the irony of your statement, ha! It's not an excuse, it's probable cause! Fear not! http://i1214.photobucket.com/albums/...318_201725.jpg Here is a shot of my mockup apparatus, it's all highly technical http://i1214.photobucket.com/albums/...302_115140.jpg |
Good job can't wait to see it done. Have you seen those bolts that have l.e.d lights in them? Maybe use those for licence plate lights?
Hey, good idea! Why didn't I think of that!
Ah, 10-4. I thought you were deleting the lighting entirely just for the smooth look. --although your state's laws do say the lighting shall not be anything other than the original manufacturer. I don't know how strict, if at all, the law dogs would be on something like this where you live? Most of them probably weren't even around when these trucks were built and probably wouldn't know original from non-original.
(Post 16136199)
:-drink |
