Side Glass - Opinion 1 piece or stock
So when I bought this project it had no side windows at all, except for the vent windows, it's time to think about whether I want to go with the original type side glass with vent or one piece side glass, I've read some here about it and either sounds like a challenge to install, I'd really appreciate some opinions on which way to go the pros vs the cons. Either way I will need everything from the window regulators to the little doo dads.
thx, Don |
I cant help you with that but,when i bought my 51 f1 it was all stock and i like the vent windows and would never get rid of them,also i have the cowl vent and it works great and i wont ever fill it in either
Are you installing AC? If not, I'd go with the vent windows. (Honestly, I'd go with them anyway, because I prefer driving with the windows down).
You asked for opinions and mine is keep the vents.
Based on your previous posts I believe that you have a 56 and are not a "keep it stock purist"...that said, the solid side window is easier to install on your truck than on a slant cab AND the look is far superior. If that is not enough...the wind noise from those vent windows is not something that you will miss. I have removed them from my 56 and my 40 coupe and I get thumbs up and thumbs down all the time but the thumbs up are 10 times the thumbs down...once again, it's what you want that matters.
I did the solid side glass on my panel with electric and on the project I'm working on now will be the same except with hand cranks , both are 56 f100's, I also filled in my cowl vent on both.
Keep the vent windows. The post will give you something to hang on to when your arm is resting on the open window sill, which Ford made higher and wider for the purpose of an arm rest as part of their Triple Economy trucks for 53-56.
So bottom line is the one piece side windows are easier to install, correct? If yes thats what I'm ordering.
Originally Posted by Don Vito
(Post 16115044)
BTW - as an added note, if you buy the glass and find that the exposed edge at the top is not smooth enough for your tastes you can easily sand and buff the edge to make it perfect. A lot like colorsanding paint. |
Hinge picket mod?
What is "you don't have all that "hinge pocket" modification to do.":-huh
Originally Posted by jonf
(Post 16127405)
I have 2 56 trucks one with vent window and one with out the one with the vent window tracks better so I would say use the vent window
Hey Don,
Hmmm... If you already have working nice vent windows - you are miles ahead. Those vent windows are hard to find & even harder to get installed correctly. I live in Texas - it's nice to have the wind blowing on you and it's one of the things along with the cowl that really stand out on the truck. Ben in Austin 1950 F1 |
Just got my vent windows rebuilt and installed and finally got the door glass installed. I really like the looks of the old vent window in old trucks. Plus the extra added wind when your running down the road with no a/c :)
If you aren't going to have air conditioning, you will regret not having vents. If you are going to have air, it doesn't matter.
