Convert Cab And Chasis 2015 ford F-350 to a Standard Dually Bed
I Really Need Help With this issue, any advice would help..
I bout a brand new Ford 2015 F350 With Bed and Chasis. Installed a Flat Bed on the frame and want to remove it and install a dually Bed on this frame........ The frame is not the same as your standard dually. I need help to Modify and install to this Truck since I don't use the flatbed.......... |
Yes, the frame is different, so is the rear axle [it's narrower on the Cab&Chassis model].
Swapping the rear axle with a wider one, but it won't line up with the mounts on the cab&chassis. After the axle swap, just putting a bed on the frame is unlikely to result in it lining up right with the cab. You probably can do it, with enough time money and effort. But you probably will be ahead money and time-wise trading for a regular dually. |
