Ford Truck Enthusiasts Forums
-   1987 - 1996 F150 & Larger F-Series Trucks (https://www.ford-trucks.com/forums/forum28/)
-   -   smog pump delete (https://www.ford-trucks.com/forums/142167-smog-pump-delete.html)
kjgibson2 03-07-2011 03:46 PM
Originally Posted by ditchdoc99 (Post 9159656)
Well I removed all the smog crap from my 460, I gained about 2mpg.. I still need to measure and get the correct size belt so I can remove the smog pump, there's nothing hooked to it but I'd like to remove it... Does anyone have a part # for the correct size belt??? The truck runs great...
Also I removed the EGR and as suggested in post # 21 I installed the Original EGR Eliminator $20.00 from RJM Injection Tech EGR Eliminators ... Worked as described no CEL
What all did you delete? EGR valve, air pump, what else, and are you sure about the mileage increase? If you got 2 more MPG's that's awesome. i could look forward to 10-13 mpg's lol
kjgibson2 03-07-2011 03:55 PM
I was looking at the RJMinjectiontech site, I have a 1992 460, do I need the original EGR delete plug and the EGR eliminator 2 or can I just get the Eliminator 2 and put it into my harness?
ceetwarrior 03-07-2011 05:20 PM
I removed my smog pump/tubes/hoses. Then I just welded the a cap on the cat where the smog pipe used to go. I left all the EGR stuff..
I haven't noticed any gas mileage or power increase but it sure cleaned up the engine bay, much easier to work on passnger side of engine.
02dynadude 05-22-2014 04:52 PM
great info guys, thanks for all of the posts. i cant wait until someone adds some pics or a detailed description of the entire process.:-drink
mramc1 05-22-2014 05:16 PM
I wrote up a process with pics from my truck this past winter.
https://www.ford-trucks.com/forums/1...with-pics.html
© 2018 MH Sub I, LLC dba Internet Brands
