302 towers
I have a 76 f-100 4x4 with a I6 300. I built a 302 and its going to be put in when I get time. My question is are they the same towers or do I need to find a set for a 302?
The I6 perches are taller which will cause problems for your 302. You can pull a set from a donor truck or you might be able to find some new.
Hope this helps! |
You need to get get a set of the 351m/400 perches. Bronco graveyard has them new for 175 plus shipping. I'm trying to locate locate a used set right now as well.
