Replacing brake pedal assembly
Would anyone be able to highlight the exact procedure for replacing the brake pedal assembly? I have a '79 Bronco that I'm converting to manual trans and have obtained a clutch/brake pedal assembly from a '79 F-150. Just not sure exactly what the process is.
3 Attachment(s)
Remove the dash bezel and the instrument cluster to have a better view and access. Then remove the pedal assembly and bolt in your new one.
