1995 F-350 headlights
Help. My 95 F-350 headlights will not shut off and the horn blows continuously. Also the door chime for the key in ignition chimes rather the key is in the ignition or not. Also the theft flashing light flashes continuously. What the cuss is going on? Thank you to anyone who might have a clue.
Billy Frederick |
Did you smell anything burning before this happened? Sounds like you had a melt down
Originally Posted by Bird-Dog 250
(Post 16045208)
Thanks for the reply, Bird Dog. Billy Frederick |
Did a previous owner crappily install alarm/keyless entry? Sounds like that is likely the issue, there is no factory system on this old of a truck that I'm aware of (could be wrong but I've never even seen a flashing theft light) that flashes lights or honks horns.
95 F-350 horn and lights
Originally Posted by PlumCrazy7
(Post 16047629)
I am the original owner and that is the mystery. I can hook up the batteries, crank the engine, let it run for a time, and about 10-15 minutes after I shut the engine down, the horn starts blowing continuously. Just noticed the last time that the headlights were on. Pulled the headlight switch out of the dash and they continued to be lit. It has to be a relay of some sort. Thanks for replying. Billy |
1 Attachment(s)
The 1995 trucks had a factory anti-theft option. Check the owner's manual for how to disarm it.
Update - I just remembered, I posted the relevant owner's manaul pages to another forum site a while back. In case you don't have an owner's manual, here they are: |
There is no relay for the headlights, power comes from the fuse to the switch then straight to the lights, you've got wires crossed somewhere.
If you pull the horn pad off the wheel does it quit?? |
