Steering Column Help
I recently had to fix the steering column lock acuator on my 96 F250. I am having problems getting the steering column back together. Debating replacing entire column. Any suggestions? Advice?
Too vague. What part of it can't you get back together?
I have the starting at the tilt mechanism
Just keep at it man. I just did the same thing not long ago. It seems to be alot of stuff but just take it one section at a time
It is a bit hard to put together, the tilt part, because of some large springs. Not impossible though. Take a pic of it and post it, maybe I can help
Sorry so long between posts, work has has me bowed up the last couple of weeks. I have found a complete steering column for my truck. Everything matches except it doesn't have the push button OD on/off. Would I be able to just put my gear shifter and electronics on that column? Or will it not work at all?
