Ford Truck Enthusiasts Forums
-   1948 - 1956 F1, F100 & Larger F-Series Trucks (https://www.ford-trucks.com/forums/forum41/)
-   -   For sale, swap and wanted 48-56 Ford, Mercury trucks & parts. (https://www.ford-trucks.com/forums/1419093-for-sale-swap-and-wanted-48-56-ford-mercury-trucks-and-parts.html)
Fomoko1 02-03-2016 10:52 PM
We`ll try to to see if it works so go hard.
Remember that it is only for Ford, Mercury parts, not for any other items and of course as always there is to be no commercial selling of any kind.
Please be sure to ask me to delete your ad when no longer needed.
Please use this thread for posting ads only, use pm`s for questions.
Any trucks, items found or sold please edit it or pm me so I can remove it. Thanks!
bhalemail 12-14-2016 10:28 AM
WANTED: Center shift lever for 3spd Heavy Duty T87D
I know this is going to be tough but i'm looking for a center shift lever for a T87D 3 spd heavy duty. I purchased the transmission and the shifter that came with it was for a 3 spd light duty and they are different. I possibly could weld some material on the bottom and mill it so that it would work but figured i might as well see if i can find the right one first.
Jwgood85 12-22-2016 09:52 PM
I am looking for a set of doors for my 54 ford f100. Please post pics and price and location please. Thanks
bjmayberry2 12-28-2016 10:38 PM
Tom
On the Bottom & Top of each page there is a bar that shows current page number & allows you to go back all the way to the beginning of the tread.
26tudor 01-07-2017 11:01 AM
Thanks USCG I think they are a good set of boards that's neat about making them fit the panels.
Jim
mbpsycho 01-15-2017 06:50 PM
i ordered wrong parts from LMC bed strip kit steel 51-52 $49.95
and wrong bolt set hood hinge $7.95
any one close to Delaware ill save you shipping .......contact me
zolav8 01-19-2017 09:53 AM
Still looking for hinges and all other hardware for the rear barn doors of my 1954 Panel truck.
Or maybe two complete doors?
https://cimg5.ibsrv.net/gimg/www.for...62af784a2b.jpg
df85732 01-19-2017 07:58 PM
WTB Emergency Brake Drum
2 Attachment(s)
I have a drum but it's pretty much shot. 8" x 2" Part # 8d-2614 Looks like this...................................
ALBUQ F-1 01-20-2017 03:50 PM
48 - 52 parts
---------- SOLD -----------
bjmayberry2 01-22-2017 03:32 PM
Wanted 53-56 hood flip kit.
Anybody got a 53-56 hood flip kit they wanna get rid of?
GoldCo 01-23-2017 08:31 PM
A couple of sweet trucks for sale: F3 fire / F6 flat dump
Not mine (and no connection). Just found these while "window shopping" on CL.
I have seen that F6 in person before in town tho:
1950 Ford F-3 Pumper Fire Truck
1950 FORD F6 Dump truck
ulnpiper 01-24-2017 10:45 AM
Free to a good home, gas tank out of '48 F1
I replaced this because I was getting rust sediment in my carb and fuel pump bowl. Some rust inside, surface rust externally. Was used with Ethanol gas, so also has a light layer of orange/brown slime inside.
Not sure why anyone might want it, but thought I'd post it before taking it to the recycle yard.
It appears to have been repaired in the past and I have no idea if it's original or not.
Pay the shipping and it's yours.
my zip code is 31328 in GA if you want to estimate the shipping costs.
https://cimg7.ibsrv.net/gimg/www.for...1c8f29a9eb.jpg
https://cimg3.ibsrv.net/gimg/www.for...7f3ca59a65.jpg
https://cimg5.ibsrv.net/gimg/www.for...4586aeed6b.jpg
https://cimg5.ibsrv.net/gimg/www.for...d3c756dab2.jpg
ALBUQ F-1 01-25-2017 04:53 PM
48 -52 F-2/up trans rubber cushion (mount)
For the 4-sp spur and other HD trannies that use the "deep" crossmember. Rubber is in really good shape except where it sticks above the crossmember, not a critical flaw. Bolts and nuts are good and free in the mount. I also have the lower plate if you need it.
$20 + shipping
https://cimg6.ibsrv.net/gimg/www.for...05c195c771.jpg
https://cimg5.ibsrv.net/gimg/www.for...92fe8d6364.jpg
kens65fb 01-27-2017 01:37 PM
49-52 and 53-56 Parts for sale --- MUST GO !!
1 Attachment(s)
I have decided to go the Mustang II route in my restoration, and I have some parts for sale.
I will also pay for 1/2 the shipping costs as well
I'm located in PA Zip 18612
Reply to : [email protected]
CCP #CPP5356PSK 1953-56 Ford Truck Power Steering kit
The compact 400 Series™ power steering box utilizes late model steering technology for your classic. These are a direct replacement for the original manual steering box and keep perfect alignment with the OE or aftermarket column. The compact design is closely modeled after the original manual steering box.
With its 13.6:1 ratio (2.75 turns lock to lock) it has the performance handling of many rack and pinion conversions without the need for extensive modifications. It has a ¾"-30 input shaft, uses inverted flare hoses (11/16"-18 pressure fitting & 5/8"-18 return fitting)steering Custom pitman arm included in steering linkage kit for Ford trucks The perfect solution for your bolt on performance power steering need!
Brian Brooks 01-29-2017 01:34 PM
55 Ford F100
I'm looking for the rear fenders, bed, & other parts for my 55 F100 if anyone has some or knows where to find some I would greatly appreciate any info!
THANKS
