Hubs hubs, roll call for 4wd hub parts
Hello
I'm having withdrawals My need is for Ford parts The pieces are in the front 4wd hubs My spring ate the hub assembly bearing retainer It literally wore/melted right through the plastic outer retaining plate bearing assembly. Have you seen this, help if you know where to find it If you have one, know of one, let me know.. |
A pic of the hub your looking for would be helpful :D as well as the year X you have.
Originally Posted by harley4jcs
(Post 15940519)
00-04 super duty details Truck is 00 |
4 Attachment(s)
Find out the answer, fantastic.new I can post pics, the other piece is an impeller of a Volvo sea box.disregard
Here is what I think happened
The inner workings of the plastic actuator has the "stepper" system. 2 ramps and a retainer. If it is depressed too far to the outer hub the ramps by pass the retainer and the engagement spring takes over pushing the actuator past the stop. Is that an accurate description off how the system engages? I haven't pulled them apart to confirm and haven't had them apart for months to review |
PM sent.............
