Dana 60 Differences
I have a 1988 F-350 4x4, and I'm needing a new hub. I dont know if the dana 60 has changed at all over the years other than the switch between the king pin and ball joint axles. My question is whether or not the hubs have changed at all from year to year. I've found a dana 60 from a friends 2002 f350 that a tree fell on in a recent storm, and he said he would sell the axle to me for $250.
I'm looking at all my options here, his truck is running 4.10 gears and mine is 4.56, but if the gears are interchangeable, I would just swap the entire axle in, if not, but the hubs are, I'd change out the hubs. I'm buying the axle either way, but I would like to know if anyone has any knowledge about this offhand. |
don't bother. that axle will not fit in your truck, and none of the parts are interchangeable.
Originally Posted by tjc transport
(Post 15845847)
Okay, thanks. What year did the axle change? |
Originally Posted by OkieFromMuskogee
(Post 15846081)
92-94 ball joint, with Pin on calipers 95-97 ball joint, with Bolt on calipers 99-04 ball joint Bolt on calipers 8 on 170mm bolt pattern, unit bearing hubs 05+ ball joint, bolt on calipers, coil springs 8 0 170mm bolt pattern, unit bearing hubs |
Might want to double check that axle. Many SuperDuty trucks still used the Dana 50 in 2002.
Originally Posted by Lead Head
(Post 15846436)
99-01 SRW F250, and F350s used Dana 50s 99+ DRW F350s used Dana 60s 02+ F250/F350s got dana 60s Excursions used dana 50s from 99-05 But the easiest way to tell them apart is the pinion nut. Dana 50 is 1-1/8" dana 60 is 1-5/16" |
'01 SRW F-250 and F-350s are Dana 50. They started putting the D60 in the SRW trucks midway through the 2002 MY.
My bad, 02
(Post 15845836)
Originally Posted by BruteFord
(Post 15848448)
As far as the hub goes all the 80-97 front D60s and D50TTBs use the same hub. Just grab one off a F250 with a D50TTB, cheap and plentiful.
I'll see if I can dig up the pic EDIT http://littlekeylime.com/MrN/img/Dan..._vs_60_013.jpg |
The picture says you can use the same hub, just not spindles...
Originally Posted by Diesel_Brad
(Post 15848524)
Nope. The 50 and 60 use different hubs. There is about 1/4" difference between them
(Post 15848598)
Hubs, bearings, rotors, lockout hubs, and calipers are the same. |
Awesome!! Thanks for all the good information!
This may be a dumb question, but I assume that they ran a 8 lug on the 50 as well correct? If so, I'll run to the junkyard once I get a chance and pull one. |
(Post 15849113)
easy way to tell a D44 from a D50-D60 :
if the locking hub is slightly smaller than the mounting flange, it is a D44. if the locking hub is the same size as the mounting flange, it is a D50 or D60 D44: http://i41.photobucket.com/albums/e2...res/D44hub.jpg D50-D60: http://i41.photobucket.com/albums/e2.../d50-60hub.jpg |
