firing order 1982 351w
i just got this truck and i am not too familial with this motor. I believe it is a 351w calif. model. my problem is I am not sure of the firing order. I am looking in a hayes manual and it states that the order is counterclockwise 1-3-7-2-6-5-4-8. My distibutor has a #1 on it and I am assuming that it is for the #1 plug wire? All the plug wires are in the correct order but the truck is gutless and backfiring please help!!:confused:
Are you sure that you have a 351W? The 302 and 351w look a lot a like. the 302 firring order is 1-5-4-2-6-3-7-8.
you are correct the 351W and the 302HO firring order is 1-3-7-2-6-5-4-8. if you have the wrong firring order the engine will run but will have almost no power and will back fire a lot. I would recomend doing a compression check to give you a better feel for the condition of the valves and rings. Good Luck. |
jpourner is correct. Try the other firing order if you want to.
Or if you want just measure the width of the intake on your engine and compare it to a car/truck that you know has a 302 in it. If yours measures the same then you have a 302 or 289 (the 289 has the 302 firing order). If yours measures about 3/4 inch wider then you have a 351w. |
If it's a California truck it's a good chance the ignition is EEC-III (brown grommet on ignition module.)
The EEC-III distributor rotor fires alternately from both sides of the distributor rotor. The firing order you listed is correct for a 351w, but the spark plug wires for an EEC-III distributor will be wired counter clock-wise in a different order. 351w firing order, CCW: 1-3-7-2-6-5-4-8 351w wire order, CCW: 1-5-7-8-6-3-4-2 Similar for the 302: 302 firing order, CCW: 1-5-4-2-6-3-7-8 302 wire order, CCW: 1-3-4-8-6-5-7-2 |
Originally posted by horsepuller If it's a California truck it's a good chance the ignition is EEC-III (brown grommet on ignition module.) The EEC-III distributor rotor fires alternately from both sides of the distributor rotor. The firing order you listed is correct for a 351w, but the spark plug wires for an EEC-III distributor will be wired counter clock-wise in a different order. 351w firing order, CCW: 1-3-7-2-6-5-4-8 351w wire order, CCW: 1-5-7-8-6-3-4-2 Similar for the 302: 302 firing order, CCW: 1-5-4-2-6-3-7-8 302 wire order, CCW: 1-3-4-8-6-5-7-2 Huckermat....keep that in mind if anything ever goes wrong with that system just toss it and swap in a non-california type distr. and ECM box. |
