Ford SuperDuty Diagnosis on the Cheap
1 Attachment(s)
This will be a multi-part write-up, covering how to diagnose, monitor, and run tests on Ford Super Duty Trucks, focusing on the Ford 7.3L Super Duty as that is the truck that I own, but these tools work for all Super Duty Trucks. Warning: Some technology experience may be required The write-up will go as follows: PC Based Diagnosis Testing and monitoring with Forscan Android Based Diagnosis with Forscan Lite Android based Monitoring with Torque Pro Android based Self Tests with CarGauge Pro I will be posting these over the next few days. Starting with PC based Diagnosis. Disclamer: I have no affiliation with any of the programs or devices mentioned in this article, I am simply a power user. Since I am hosting some of these images on my server(forum wont let me post more than 5 images per post). I have created a PDF of my walkthrough in case my server is offline or the images become inaccessible. |
Part 1: PC Based Diagnosis with Forscan Everyone on this site has heard of AutoEnginuity, It really is an awesome tool, but when I first heard about it I thought it was crazy, I am a big proponent of Open Source Software and decided to see if there was something cheap or free that would work. Forscan is a piece of free software that I found, it is not open source, but it works really well. Now on to the how to! Required Items:
Important Note: This tutorial is written on a PC running windows 8.1 but has been tested on Windows 7, 8, 8.1, and 10. Step 1: Download and Install Forscan for Windows from their website: Download FORScan Step 2: Connect your USB ELM327 Adapter to your laptop and to your truck. http://scoutcamper.com/diag/laptop_obd.jpg Step 3: Open Forscan on your laptop You should be greeted with a screen like this: http://scoutcamper.com/diag/forscan_connect.jpg Step 4: Connect to your truck for the first time: Note: If you are not using a usb adapter, make sure your bluetooth adapter is paired with your laptop, forscan SHOULD auto-find and connect to it when you follow these steps. Click on the connect button circled in red http://scoutcamper.com/diag/forscan_connect.jpg You will get a popup telling you what is required for it to connect, TURN THE KEY ON, then click OK on that popup. http://scoutcamper.com/diag/forscan_connect2.jpg Step 5: Answer Questions You will get this popup http://scoutcamper.com/diag/forscan_connect_iso.jpg Unless your adapter has a physical switch on it click NO Then you will get this http://scoutcamper.com/diag/forscan_connect_profile.jpg Click Yes. This creates a profile for your truck. From that point forward anytime you connect the Forscan app will remember your dashboard PID’s, which we will get to in a bit. Now that we are connected, let’s get to the useful part of this. DTC checking Step 1: click on the DTC tab http://scoutcamper.com/diag/forscan_select_dtc.jpg That will take you to a screen showing you all of your DTC’s, including Ford Specific, and a brief explanation. http://scoutcamper.com/diag/forscan_dtc.jpg You can click on any of these DTC’s to see more details. Click on the self tests button. http://scoutcamper.com/diag/forscan_select_test.jpg Then you will see a list of available self tests. http://scoutcamper.com/diag/forscan_self_test.jpg Pick whichever one you want to run and then click the red circled play button, the interface will walk you through them. These self-tests are explained in many places on the forums, I will not be re-explaining them here. One of the most common things to do with your OBD interface is to monitor parameters in the truck to test for things like a Failing ICP/IPR. To monitor your truck you will connect as described above. After that, click on the dashboard icon. http://scoutcamper.com/diag/forscan_select_dash.jpg You will see the following screen http://scoutcamper.com/diag/forscan_datalog.jpg But that doesn’t really help, there is no info there! Double click on any of the white boxes and you will get a popup http://scoutcamper.com/diag/forscan_pid_pick.jpg Scroll around and find whatever you would like to monitor. There is more here than the 7.3 supports, so some may not work. When you find one you want to monitor, simply double click on it. When you are done, click the checkmark at the bottom of the popup. That will take you back to the datalog screen. To start actually viewing data click the play button I have circled below. http://scoutcamper.com/diag/forscan_datalog_live.jpg This is how the data will look. This concludes the PC Forscan part of this Tutorial. Next up, android! |
Disclaimer: This tutorial is written with screen shots from a Samsung Galaxy Note 4, but has been tested on half a dozen different phones. Required items: Bluetooth OBD Reader(I use this one: Amazon.com: Vgate Bluetooth Scan Tool OBD2 OBDII Scanner for TORQUE APP ANDROID: Automotive ) Android Phone or Tablet Super Duty truck! Now, to start we need to buy the Forscan Lite app. There is a free app that you can use for testing, this tutorial does not cover that. Step 1: Open the google play store, search for Forscan Lite, purchase and install it. http://scoutcamper.com/diag/android/...rscan_play.jpg Step 2: Connect your Bluetooth obd reader to your truck and turn the key on. http://scoutcamper.com/diag/obd_bt_connected.jpg Step 3: Pair your OBD reader to your phone http://scoutcamper.com/diag/android/...ect/BT_OBD.jpg Your phone will ask you for a Bluetooth pin, usually this is 0000 or 1234 Step 4: Open the Forscan app http://scoutcamper.com/diag/android/...ppLauncher.jpg Step 5: Configure the app, scroll down to settings, click settings http://scoutcamper.com/diag/android/...n_settings.jpg Step 6: In the settings menu make sure Demo mode is not selected and your OBD reader is selected. http://scoutcamper.com/diag/android/...gs_confirm.jpg Step 7: Connect to the truck. http://scoutcamper.com/diag/android/...an_connect.jpg Wait for the light to turn green http://scoutcamper.com/diag/android/..._connected.jpg Step 8: Select Errors http://scoutcamper.com/diag/android/...can_errors.jpg Step 9: See what DTC’s your truck has. http://scoutcamper.com/diag/android/...rscan_dtc2.jpg The Red Circle clears ALL DTC’s, the Green Circle re-scans for any DTC’s. Step 10: Disconnect Click the button in the green circle to disconnect when done. http://scoutcamper.com/diag/android/...disconnect.jpg |
Disclaimer: This tutorial is written with screen shots from a Samsung Galaxy Note 4, but has been tested on half a dozen different phones. Required items: Bluetooth OBD Reader(I use this one: http://goo.gl/aVPJLa ) Android Phone or Tablet Super Duty truck! Now, to start we need to buy the Torque Pro app. There is a free app that you can use for testing, this tutorial does not cover that. Step 1: Open the google play store, search for Torque Pro, purchase and install it. http://scoutcamper.com/diag/android/...orque_play.jpg Step 2: Connect your Bluetooth obd reader to your truck and turn the key on. http://scoutcamper.com/diag/obd_bt_connected.jpg Step 3: Pair your OBD reader to your phone http://scoutcamper.com/diag/android/...ect/BT_OBD.jpg Your phone will ask you for a Bluetooth pin, usually this is 0000 or 1234 Step 4: Open the Torque Pro app http://scoutcamper.com/diag/android/...nch_torque.jpg Step 5: Open torque settings to configure the app. http://scoutcamper.com/diag/android/...en_torque1.jpg Step 6: Click on Settings http://scoutcamper.com/diag/android/...orque_gear.jpg Step 7: scroll down on the screen until you find and click on “Manage Extra PIDs/Sensors” http://scoutcamper.com/diag/android/.../settings2.jpg Step 8: click on the menu button in the top right http://scoutcamper.com/diag/android/torque/pid1.jpg Step 9: Click on “Add Predefined Set” http://scoutcamper.com/diag/android/...pid_option.jpg Step 10: click on “Ford (Incl. Powerstroke)” http://scoutcamper.com/diag/android/...pid_select.jpg Step 11: Verify you see a large # of new PID’s on the screen http://scoutcamper.com/diag/android/torque/pid2.jpg Step 12: Press the back button to get back to the settings screen, then click on “OBD2 Adapter Settings” http://scoutcamper.com/diag/android/...d_settings.jpg Step 13: Verify connection type, choose Bluetooth device if you wish, Torque will auto find OBD readers if you do not pick. http://scoutcamper.com/diag/android/...settings_2.jpg Step 14: Back all the way out to the home screen of the torque app. Verify that Torque connects to your reader. The Red Circle is your GPS Lock, does not matter for monitoring The Green Circle is your device indicator, it should always be lit The Blue Circle is connection to OBD reader The Orange Circle is the OBD reader’s connection to the PCM http://scoutcamper.com/diag/android/...pen_torque.jpg Step 15: Click on realtime information http://scoutcamper.com/diag/android/...en_torque2.jpg Step 16: Note that you can swipe left and right to get to an empty screen of gauges http://scoutcamper.com/diag/android/...e_realtime.jpg Step 17: press and hold on the screen until you see a popup, then click add display http://scoutcamper.com/diag/android/...dd_display.jpg Step 18: Select the type of display you want, I like Dial (needle) http://scoutcamper.com/diag/android/...splay_size.jpg Step 19: Pick the PID you want, for Example ICP http://scoutcamper.com/diag/android/...id_display.jpg Step 20: Pick a size http://scoutcamper.com/diag/android/...lay_size_2.jpg Step 21: tap the location you want the gauge, you can also drag it to the grid lines http://scoutcamper.com/diag/android/...splay_drop.jpg Step 22: When you tap or release your finger the gauge will lock there. http://scoutcamper.com/diag/android/...rque_gauge.jpg Repeat steps 17-22 for each gauge you want to add. |
Disclaimer: This tutorial is written with screen shots from a Samsung Galaxy Note 4, but has been tested on half a dozen different phones. Required items: Bluetooth OBD Reader(I use this one: Amazon.com: Vgate Bluetooth Scan Tool OBD2 OBDII Scanner for TORQUE APP ANDROID: Automotive ) Android Phone or Tablet Super Duty truck! Now, to start we need to buy the CarGauge Pro app. There is a free app that you can use for testing, this tutorial does not cover that. Step 1: Open the google play store, search for Car Gauge Pro, purchase and install it. http://scoutcamper.com/diag/android/..._Car_Gauge.jpg Step 2: Connect your Bluetooth obd reader to your truck and turn the key on. http://scoutcamper.com/diag/obd_bt_connected.jpg Step 3: Pair your OBD reader to your phone http://scoutcamper.com/diag/android/...ect/BT_OBD.jpg Your phone will ask you for a Bluetooth pin, usually this is 0000 or 1234 Step 4: Open the CarGauge Pro app http://scoutcamper.com/diag/android/...e_launcher.jpg Step 5: Click on connect. http://scoutcamper.com/diag/android/...in_connect.jpg Step 6: Select your OBD reader from the popup http://scoutcamper.com/diag/android/...ge_bt_list.jpg Step 7: Select your vehicle manufacturer (FORD!! :icon_ford: ) http://scoutcamper.com/diag/android/...Gauge_make.jpg Step 8: Select the Ford Powertrain Module http://scoutcamper.com/diag/android/...ge_module1.jpg Step 9: Select the ECU http://scoutcamper.com/diag/android/...rGauge_ECU.jpg Step 10: Select Auto-Scan for PID’s http://scoutcamper.com/diag/android/...rGauge_PId.jpg Step 11: click cancel when asked to save the PID list http://scoutcamper.com/diag/android/...uge_Export.jpg Step 12: Click Diagnostics http://scoutcamper.com/diag/android/...Gauge_Diag.jpg Step 13: Select Self Test http://scoutcamper.com/diag/android/...auge_Diag2.jpg Step 14: Select the test you want to run, for example a Buzz Test http://scoutcamper.com/diag/android/...auge_Diag3.jpg Step 15: let the test run until the red goes away http://scoutcamper.com/diag/android/...auge_Diag4.jpg Step 16: Observe any leftover P codes, deal with accordingly http://scoutcamper.com/diag/android/...auge_Diag5.jpg Step 17: Press back button back to the home screen, then press exit when done. http://scoutcamper.com/diag/android/...Gauge_Exit.jpg |
FAQ's
What about my iPhone? More FAQ's to come as people post. |
Thank you for taking time to bring us this info. I downloaded it from the link without any trouble. I had not heard of Forscan. I have been learning Torque Pro, as I have time. Looking forward to future posts.
Nice write up! Thank you.
I have actually posted the rest of the tutorial but it is currently sitting in the moderator queue...
Anything avail for Macbook?Or do I steal my boy's laptop?
Thanks |
Good job on taking the time to start this thread and collect the screenshots. I know from experience this is an involved process, and that many will benefit from your efforts.
I downloaded FORScan a week or so back, but have not yet had time to install it. |
Can you use the AE ODB II adapter to communicate with FORscan, or will they not play well together?
Thanks , Scout! Reps sent!
Originally Posted by Dave in Maine
(Post 15834990)
Thanks
Originally Posted by Rikster-7700
(Post 15835325)
I may have to try just to see, if I get chance I will let everyone know
