Who sells non billet 3" plenums?
As the title says who sells them? Gonna switch to the 3" on my obs, I just want the stock SD 3" intakes.
Originally Posted by ReBilld
(Post 15794332)
Each, just like Ford and I would strongly suggest the Plenum inserts they offer as well.
Sd plenums won't fit with obs turbo. I have a project for a guy and tried to use then and is a nogo. The riffraff billets are a nogo. Sadly as much as I despise them irates flat plenums fit. They are aluminum but not billet,just a flat aluminum plate/tube setup.
Originally Posted by fordman67
(Post 15794531)
Originally Posted by duck fan
(Post 15795146)
Problem with these is that with the way the tube is welded to the plate they cause all kinds of turbulence. They also have a real problem staying sealed to the head.
That also is why I built my own set. They however will fit with the obs turbo. |
(Post 15795226)
Yep. Hence the I hate to bring them up.
Originally Posted by Ezalycasaid
(Post 15794315)
https://cimg6.ibsrv.net/gimg/www.for...5389781ca5.jpg |
Originally Posted by nateairman
(Post 15797005)
Do you have some photos? I imagine exhaust pipe cut and fit would be the ticket...
What do you wanna see |
My plenums do not leak but the boots keep sliding up into the spider and leaking. I am hoping to make the pipe larger so I don't need a steped boot or weld a ring onto the stock plenum to stop the boot from sliding up.... Its easier to weld the ring on as I would leave the plenums in the truck to weld but it is risky....
