Originally Posted by Tim Hodgson
(Post 15803991)
Head's up from today:
"...I do have some good news! I had the rear radius arm bushings replaced and they were totally shot. With the new bushings in place I could tell that some slop had been removed but the death wobble was still present and even easier to set off now. Again, to re-iterate what I have found: Death wobble is much more likely to be initiated where there is ALMOST no play in the steering system rather than lots of play. That seems to be the combination that really gets it going from the smallest imperfections in the road surface. I used to have all kinds of slop and no death wobble, it is only when you nearly but not completely eliminate it that you have an issue. So I brought it back to Boulder Offroad and they found that the tie rod ends were completely shot and I had some sway bar and shock bolts that came loose. They replaced the end links and tightened everything up and no more death wobble! I am guessing that the end links were destroyed from the death wobble itself when some of the other components were causing it. Right now she drives pretty well and I have not been able to get her to violently shake. Fingers crossed that this lasts for a while!" Sportsmobileforum.com ? View topic - Death Wobble - Possible Resolution cpye2: You don't have radius arm bushings (because you don't have radius arms like us coil suspension guys do) but maybe take a look at your tie rod ends? |
(Post 15804499)
Dude, 100+F 180 days/yr.? Where are you located? Phoenix? Post your general location. And there may be someone near to you who can lend a hand. This place is called the "Brotherhood" for a reason. And then, in the future if you feel you have gotten some value out of this website, put up $19 and become a member. But regardless, help others here because you are well on your way to knowing more about your rig than most. Reps to you.
Originally Posted by cpye2
(Post 15802765)
Just ordered a grease fitting so I can grease through the brake sensor hole and some NAPA Ceramic pads. Went ahead and got XFR ball joints. Today I got some pullers to finish taking apart the hub assembly. Maybe Thanksgiving before I can get all this on.
I don't use a special tool for those seals. I cut a hole big enough for the stub end to fit through a hardwood scrap piece and built a wood "U" truss taller that the stub end and drove it on. Much cheaper. 4 nails and 4 pieces of wood.
Originally Posted by Zwalters
(Post 15805100)
I haven't tried it yet (but I do have a tie rod to install) but I have it on good authority that if you use an air hammer (cheap at Harbor Freight) with a blunt (cut off?) chisel bit, and use it on the side of the tie rod ball joint while putting some sort of pressure (pickle fork, tie rod separator) on the gap in the tie rod joint, that it will separate easily.
No personal experience, yet, just passing on what I have been told... |
Don't know of a way to check the rotors once off unless you have a brake lathe. As for swapping them from side to side, never heard of that, or I guess you're talking about rotating them like tires, I wouldn't do it.
If you have any lathe with enough swing, you can use a 3 or 4 jaw chuck and grab the inner lip (mating surface) and run a dial indicator on it.
If not, you can flip the rotor and install it backwards. Need a deep socket to tighten it up with the lug nuts. Use a dial indicator to check for warp. Use a marker on the non-pad contact surfaces to mark high and low. Just a note, most of the time, unless it's a really cheap rotor, they don't "warp". Most of the time there is a pad impression left on the surface of the rotor. This is how it happens: You brake hard and heat up the rotors and pads. You stop at a light and hold the brake down fairly hard because our trucks will creep if you don't. The pad delaminates a tiny fraction and/or leaves some components from the hard braking. When you pull away, it leaves the imprint in the form of a raised area. You feel surge in your brake pedals and some vibration. Since the imprinted area is similar in material to the pad, build up occurs at the imprint and it gets worse over time. If you catch it in time, you can go back through a breaking in procedure for your pads and sometimes it will work. I give credit of this knowledge to the owner of Applied Rotor Technologies whom with I had several long conversations about this issue and his product. Doing more research, I have found that sometimes a more aggressive pad will clean off the rotor, but this is also at the expense of rotor life. The more aggressive the pad, the shorter the rotor life (in terms of wear). Don't rotate your rotors. There is some sort of metallurgical/engineering reason it increases the risk of damaging the rotor or having warping and develop stress fractures. I never got the dirty on that one, but a friend of mine who is an engineer for a defense contractor told me they learned this lesson on an expensive piece of gear. |
(Post 15805203)
Both ball joints fall over with gravity, and the lower has in and out play on it. The axle seal was warped also. U joints are good though! Cleaning parts now and waiting on parts to come in so I can rebuild. Bout to check the caliper pins and piston. They look pretty bad from the eye test right now, but I havent extended the piston. So maybe its the outside looking rough.
Got a froze piston in the left side caliper. I went ahead and bought the brake kit from Jegs. No core charge, and free shipping. $305. Part # KC1905-36. I do have an extra set of auto lock o rings now, and an extra set of brake pads. I can keep the brake pads for later, but will never nead these o rings since I have Warn hubs. So after all this the only thing left to replace to completely rebuild my front end are sway bar, trac bar and leaf spring bushings, shocks, tie rod ends, and a new stabilizer.
Originally Posted by Y2KW57
(Post 15797260)
CPYE2, from your last description of symptoms, it seems fitting to start with the left front brakes... Check for smooth operation of the slide and caliper pistons.
(Post 15809857)
See CPYE2... you successfully self diagnosed. |
1 Attachment(s)
(Post 15802765)
You can see lateral runout on the rotor with an elaborate rig like below. I put a brick on the wrench to hold it steady. I was "clocking" a new rotor around on the hub looking for where their cumulative runout was least. Not really needed but I had time, and eventually I found a sweet spot. |
Does it have to be a Craftsman 15/16" wrench?:-X22
I will do that next brake job. |
I took apart the right hand side to go ahead and clean parts and get it ready for replacement when the new stuff comes in. Like the left hand side, the thrust washer was in inside out and the O ring around the hub was missing. The back side of one of the manual hubs had come apart inside the hub, but I dont think it caused any wear. I believe I can put it back together and probably should have taken the other side apart like this one just for extra cleaning. Needle bearing was still greased and hub was tight. U joint was tight. Axle seal was WAY worse than the left hand side. My inner axle seal on this side is also leaking. I noticed the slow drip a few months ago and this confirms it was coming from the differential. Didn't get time to take a look at the caliper, but it is getting replaced at the same time with the other side. Next step is to press out the ball joints and press in the new ones.
