rear tag number what ratio ?
been awhile, I have a f250 1988 4x4 that has a f350 dually rear with these numbers on the tag V170A (top line) and 10 10 26E21 (on bottom line) anyone know what ratio. front is 410 by axle code in door jam. thanks Capt. Hugh
I believe there was two options 3.55 and 4.10
H9 is 3.55 if it's something else it should be 4.10 The code in the door |
You are missing a number. It is right before the 10. Under the bolt head. You have 4.10s
as Brad said, they are 4.10 gears. if they were anything other than 4.10 you would know the instant you engaged 4 wheel drive, it would feel like you were driving with the brakes applied and then you would hear a loud sickening noise as things unloaded.
thanks
thanks guys
rpm and speed
ididnt mention that the truck is a 1988 f 250 4x4 with a f 350 dually rear , speedometer not working, I just in stalled an eletric tach on steering column, at 55 mph (gps) im turning 1750rpm, that seems low to me with 410s
iirc the truck in my sig runs in that range.
Originally Posted by Selfhl1
(Post 15735191)
If you have a C6 auto the engine speed would be a little faster due to no lockup torque converter. If you have an E4OD with lockup torque converter and 0.71:1 overdrive you should be at about 1700 rpm with 4.10s. Taller tires would lower all of those engine speeds, shorter tires would obviously raise them. |
tires and trans
stock tires 235-85-16 trans = P R N D D 1 the first D is black in a white circle and a little smaller
(Post 15735628)
deleted do to double post
(Post 15735628)
(Post 15735861)
E4OD in '88? With that gear selector I'd take a swing at it being an AOD but I've been wrong before.... |
My sometimes inaccurate decoder ring says:
This would be a Sterling axle with a 10.25" diameter ring gear, non-limited slip. <table style="border-collapse: collapse;" id="table2" border="1" cellSpacing="0" cellPadding="2" width="98%"><tbody><tr><td bgColor="#fae9d1">V170A</td><td>Ford F250, F350 Pickup 85-86</td><td align="center">4.10</td><td align="center">10.25</td><td align="center">NL </td></tr></tbody></table> |
