Gearhead SRL+ P1102 lower airflow than expected
Hi All,
I got SRL+ tunes from Gearhead and now I have P1102 and a check engine light. I also get a ton of smoke when I first stab it, my EGTS are also through the roof I can't even get to WOT without shooting over 1300 degrees. Truck has a 4 inch downpipe and 5 inch straight pipe from there back so exhaust flow should be great. I am wondering if maybe the AFE intake could be causing to much restriction, it was there when I bought the truck but I did just put a new 7 layer AFE filter on it.. Any thoughts? |
Clean the MAF.
I'm running SLR+ and Atlas 40, 4" pipe and no issues.... with AFE intake. I get a slight puff when I stab it. Ask Matt at Gearhead to tighten the smoke control for SLR+, that should kill the puff. Can't tell you what my EGTS are, no gauge. |
P1102 could also be caused by a boost leak, exhaust restriction, binding turbo, egr valve, or lack of proper fuel into the cylinders. Could be caused by a broken/damaged Vref wire at the Mass Air Flow sensor.
The thing is it is only when using the Gearhead tunes... If I flash back to canned SCT tunes even the performance tune I don't get the code but 8k tow and SRL+ both set it and very quickly.
Edit: it actually sets the code just at idle after about 20 seconds |
What year are we taking about? There is a 2015 listed in your info.
Sean https://cimg0.ibsrv.net/gimg/www.for...455b8d603e.gif 6.0L Tech Folder :oval |
Originally Posted by Yahiko
(Post 15531978)
Hmm. I just rechecked it and must of hit the
wrong person's "About Me" Sorry about that. What color is the smoke? It almost sounds like over fueling from what you have said so far. Also double check the strategy the tune your running was written for. Sean https://cimg0.ibsrv.net/gimg/www.for...455b8d603e.gif 6.0L Tech Folder :oval |
(Post 15532085)
wrong person's "About Me" Sorry about that. What color is the smoke? It almost sounds like over fueling from what you have said so far. Also double check the strategy the tune your running was written for. Sean https://cimg0.ibsrv.net/gimg/www.for...455b8d603e.gif 6.0L Tech Folder :oval The smoke is pitch black and really only there for a second until it builds boost then it cleans up, but in that second it is a lot of smoke. That's with the SRL+ tune, 8k tow didn't smoke bad at all but still triggered CEL. I have also been emailing Gearhead and he had me check the strategy and it definitely matches. He sent me a new file to make sure it wasn't corrupt but if that doesn't help they will write the MAF out of the tune and see what that does. |
Originally Posted by Kdawg89
(Post 15531745)
Originally Posted by bismic
(Post 15532283)
Even though it only does it with the tune, you could still have one of the problems above. It would be wise to at least look. An actual air related problem (such as with the MAF) might not be bad enough for stock, but show up with the tune.
Edit: also the truck has EGR delete so not coming from the EGR. |
(Post 15532283)
If your truck has issues, tuinng it will only intensify the issue(s) and will bring others to light. Per Mark, if your MAF (use MAF cleaner only), EGR valve (carb cleaner), EBPS, EBPS tube, and EBPS fitting at the manifold, MAP (use shop air or wire hanger to clear) nipple at the intake manifold, IAT2 in the intake manifold, haven't been cleaned, it's high time to do so. If your turbo has never been cleaned, it may be time to do so as well. I did mine just recently and it's made a world of difference boosting. |
Originally Posted by Toreador_Diesel
(Post 15532453)
I'm with Mark on this...
If your truck has issues, tuinng it will only intensify the issue(s) and will bring others to light. Per Mark, if your MAF (use MAF cleaner only), EGR valve (carb cleaner), EBPS, EBPS tube, and EBPS fitting at the manifold, MAP (use shop air or wire hanger to clear) nipple at the intake manifold, IAT2 in the intake manifold, haven't been cleaned, it's high time to do so. If your turbo has never been cleaned, it may be time to do so as well. I did mine just recently and it's made a world of difference boosting. I will give that a shot because it can't hurt anything but we are talking about it setting a code when idling for even just 10-15 seconds after the flash of SRL+ or 8K tow when other higher performance tunes don't set the code ever under any condition. By higher performance I am talking about canned SCT performance tune vs 8K tow. I could see if this code was being triggered under a high load situation with these high power tunes but it is at idle where airflow requirements are minimal. |
Once you clean everything up, make sure to run the truck till hot, disconnect the batteries for 10-15 minutes, start the truck and let it idle for another 10 minutes. This will help the truck build a new baseline.
(Post 15532274)
(Post 15532283)
You could then look at the graphic and see if the turbo is lagging much of it's response. Black smoke is over fueling or poor air flow. High EGT says the same thing. Clean and check the things that were recommended. Do you have something like the SGII to watch live data? I would also watch the MAP,VGT. Trying to think is there is others that you could watch. Do the testing with it set to stock. Sean https://cimg0.ibsrv.net/gimg/www.for...455b8d603e.gif 6.0L Tech Folder :oval |
I will do those things, truck has a new turbo and EGR delete so those 2 things are a not an issue. Gearhead doesn't think any of this is caused by an airflow problem on the truck because they can't figure out why I would get the light with SRL+ and 8K tow but not with unlimited tow or stock. They wrote a tune without MAF for it and it runs great obviously without a check engine light.
