Help with fuel filter minder
I have a 2015 F250 XLT 6.7 PSD. I bought this truck slightly used and it now has just short of 15,000 on the odometer. Since I am not the original owner, I am changing the fuel filters for a little piece of mind. In the owners manual it states to reset the filter minder. My XLT does not have the interactive display, just the basic one. Does this display have an option to reset the fuel filter minder? I have not received a message to change yet, just want to do it as a precaution. Thanks in advance for educating me on this!!
If I am not mistaken you only get the oil life monitor with that level instrument cluster. I have never seen it in there. I am a big fan of using those monitors and reset them for my customers whenever I perform any of the relevant services. I wonder why Ford left that out on those clusters. It's not like couldn't have. Conversely, we can only enable manual regeneration in the low level clusters... but not the message center clusters. GO figure!
I wonder what Ford's rational was for that? I would really like to be able initiate a manual regeneration.
Well, if its not in there, no big deal for me. Most people get the change message around 20,000 miles. I am doing it at 15,000 to be safe. If there is nothing to reset, I just didn't want a message come up to change it in another 5,000 miles! It shouldn't come on if there is a sensor for filter restriction I assume.
Originally Posted by CarlT100
(Post 15509980)
To answer your question, the "rationale" is that the low level instrument cluster is typically found in fleet vehicles or trucks with a lower trim level that are commonly used in vocational applications. A lot of these trucks do a lot of idling and very low average MPH operation and as stationary operation. The aftertreatment systems load up and rarely are given the chance to regen completely. I have several municipal customers and an airport truck that need this functionality. Conversely, performing a manual regen when it is not necessary can potentially be harmful to the catalysts and safety concerns that arise when performing a stationary regen. In my professional opinion: too many people pay wayyyy too much attention to regens and might unnecessarily perform them when they should not... despite the fact that the on-board option will not allow you to do so unless the system determines it is necessary based on pre-defined parameters. I am sure there are a few people out there that would genuinely benefit from he ability to perform a manual regen but in my opinion, some truck owners really need to remove their monitors and gauges and just drive their flippin trucks. That cluster is also the only one I have ever seen in F450 and F550 cab and chassis trucks and these have been the only models that I have ever reconfigured the modules to enable this feature. |
Originally Posted by Ford_Doctor
(Post 15511642)
This is a heavily debated topic.
To answer your question, the "rationale" is that the low level instrument cluster is typically found in fleet vehicles or trucks with a lower trim level that are commonly used in vocational applications. A lot of these trucks do a lot of idling and very low average MPH operation and as stationary operation. The aftertreatment systems load up and rarely are given the chance to regen completely. I have several municipal customers and an airport truck that need this functionality. Conversely, performing a manual regen when it is not necessary can potentially be harmful to the catalysts and safety concerns that arise when performing a stationary regen. In my professional opinion: too many people pay wayyyy too much attention to regens and might unnecessarily perform them when they should not... despite the fact that the on-board option will not allow you to do so unless the system determines it is necessary based on pre-defined parameters. I am sure there are a few people out there that would genuinely benefit from he ability to perform a manual regen but in my opinion, some truck owners really need to remove their monitors and gauges and just drive their flippin trucks. That cluster is also the only one I have ever seen in F450 and F550 cab and chassis trucks and these have been the only models that I have ever reconfigured the modules to enable this feature. Good post. Thanks Keith. I want to take good care of my truck, but I want to believe the computer will take care of things like regens. Also, I watched a guy do a manual regen on YouTube, and it took a while, and burned almost 1/4 tank of fuel. No thanks. I'd rather take it out and run it hard if I think it needs one. |
Thanks, Keith, for a very good answer. I am not a worry wart. When I am home, I don't drive my truck much. When I do, it is usually for short suburban trips. And I get incomplete regens. About the time one starts, I am two or three miles from the house and shutting the truck down. I don't worry about it on trips. It takes care of itself.
Reps sent. |
Originally Posted by 22rimfire
(Post 15511671)
(Post 15511671)
(Post 15511698)
Reps sent. My Rep gun is broke, so I will hop in here. :) |
I got him for you Tim!
Thanks, Doug !
