Difference between E250 and E250 SuperDuty?
Hey Folks,
as you know im driving a Cargo Van E250 from '97 with E40D, 330cui. It was imported by your army, i got some certificades for. now i ordered some parts ( bushings for leafsprings) for my rear axle (dana 60 far as i remember) the friend who sold me the bushings send me some small ones. doesnt fit. he asked me about the history of my van, especially about army Service. he said: they dont fit to your car because they are for E150/250/350. if your care served, it is an E250 SUPER DUTY. so this will be the reason for the bigger bushings in your rearaxle. who knows something about it? :-wink |
Military Vehicles can be made to any spec, you might need to measure the spring eyelets ID and shop by size alone...........might have a E350 weight rating.
There are multiple rear springs possibly upto 25 different kinds of leaf springs that will fit an Econoline. I recommend you check the drivers door jamb or the door for a sticker. It will say MFG by Ford Motor Company... Will have the VIN, and near the bottom will be multiple codes one will be SPG or SPR and use the second line to determine what leaf springs your van is equipped with.
That is 100% true...... the Vin and codes on the door Jam tell everything about the vehicle....depending on who originally ordered the vehicle....
http://i284.photobucket.com/albums/l...ps2adyxoo5.jpg
how you see the leafspring? haynes rep Manual is only talking about the VIN.. |
This site - Ford Spring Codes - Shop Ford Leaf Springs by Code | SD Truck Springs | Leaf Springs, Helper Springs and Suspension Parts - says rear spring code N has this replacement - 1992-2013 Ford E250, E350 - Leaf Spring (Rear - 3/1 Leaves) [43-1153] | $219.95 | SD Truck Springs | Leaf Springs, Helper Springs and Suspension Parts
Sixto 93 E150 Chateau 5.8 191K miles |
thanks mate.
now i try to find out which bearing are correct for this Special spring. very helpful, thanks ! |
Rear spring code is ULE
? ULE?
my code is LN |
Originally Posted by 98Econoline150
(Post 15483079)
(Post 15502005)
(Post 15504114)
I thought this thread was about leaf springs? If you want coil springs then LN is correct.
George |
