55 F-100 Wheelbase Mystery
Having a difficult time figuring this out.
55 F-100 Books all say 110" wheelbase. Near as I can figure mine measures 109". Working on the bare frame right now with the gear pulled off (yes.. should have marked it better!). Logic tells me the front axle lines up with the axle bumper + the TCI MII measurement also gets me to the same location. Rear, I used mid way between the two bolt axle bumper. I also bolted the original leaf springs back in place. Center of the leafs ends up in front of the 109" mark but moves to the rear as the spring compresses. Looks like it would end up at about the 109" point under load. The truck is Canadian manufactured but it's difficult to believe that makes a difference. Anyone brave enough to hazard a guess? |
Don't know if this will help you or not. Sorry, after reading your question again this wont help you.
http://www.restoreyourford.com/image...3tdims0003.jpg |
It might help but opens another question. It gives the dimension from the rear of the frame to the center line of the rear axle which should verify where my measurement is to BUT.... this dimension is for a bare cab model. Anyone know if I can assume the short box version is the same?
All F100's are short box those years. Yours is the same as posted.
Originally Posted by truckeemtnfords
(Post 15458644)
Sask
I can't help with the details, but as I read the posts, it isn't clear to me what measurements are needed. Can you re-ask your question? It might help with the responses. |
I read somewhere that you can't trust the bump stop holes as center of axle because they shifted them a little to compensate for the arc of the suspension under load.
Originally Posted by SaskF100
(Post 15456759)
55 F-100 Books all say 110" wheelbase. Near as I can figure mine measures 109". Working on the bare frame right now with the gear pulled off (yes.. should have marked it better!). Logic tells me the front axle lines up with the axle bumper + the TCI MII measurement also gets me to the same location. Rear, I used mid way between the two bolt axle bumper. I also bolted the original leaf springs back in place. Center of the leafs ends up in front of the 109" mark but moves to the rear as the spring compresses. Looks like it would end up at about the 109" point under load. The truck is Canadian manufactured but it's difficult to believe that makes a difference. Anyone brave enough to hazard a guess? Your second post a little more descriptive as to what you may want so I measured my truck and the rear of frame to axle centerline is 36.25" at ride height. Like Fortyniner said, be specific as to what you need or want and you will get a lot of help. Come off any other way and you will be on your own. There are people who know a next to nothing on here and there are guys that know everything. We never know who we are dealing with until you start to establish yourself, this helps us know how to help without assuming, which usually does not work out well for all. If you need specific measurements from a truck one of us can help, I am sure. Good luck. |
Yes, I am new here. Yes, I am a first time builder. Thanks for the slack. I appreciate all the information and all the effort. As clear as I can state:
- I want to be sure of axle locations before I weld. - Front seems good. I used the TCI MII measurement of 20.5" back from the original front spring mount and it lines exactly with the front bump stop hole. Good to go with the front. - Rear doesn't work as well. - Using the center point between the rear bump stop mount holes gives me a wheel base of 109". Not what Henry Ford designed! - Today I measured from the rear of the frame forward to the same center point between the bump stop mount holes and get 36.125" (almost the same as diagram from avf100 (35.8") and verified by truckeemthfords (36.25" - thanks by the way for crawling under your truck)). A possible issue with this is the truck had a 'highly modified' rear work bumper after I rescued it from the field after 30 years of work and 25 years of sitting. Maybe what I think is the end of the frame is not actually the original end. Anyone know the true length of an original frame rail? - So the rear axle seems like it is actually is 109" from the front not 110" as it is supposed to be. See my dilemma? I am wondering if I should just set the rear axle 110" behind the front and forget about the other measurements? Seems impossible the wheelbase is 109" but I'd rather be sure about where it goes - so I'm learning how to use this forum! |
One thing to consider on the front axle is Henry had them to the rear of the front fender opening. Most,like me and others, move the front axle centerline forward to center it in the wheel opening. As far as the rear my suggestion would be to center the axle in the rear wheel opening, if you're using a bed. If you're using a flat bed go with what looks good. I know putting a bed on may be a pain but it will guarantee the tire is centered on the wheel opening. Wheelbase is not all that critical, mine stretched due to the front axle centerline being moved forward.
Yes you should move the frt axle center line 1 1/4" forward from the stock location, to center it in the wheel well.
Saskf100, it might help if you could post some pictures of what you have and especially the areas of your concern. I'm surely not the guy who will have the answers you need, but sometimes pictures can help our resident experts spot something that you may have overlooked.
Oh, and welcome to FTE it really is the best place for help and advice. |
Sorry I'm no help but welcome to the club
First: The diagram shown above does not reflect chassis cab dimensions. It represents a completed fully loaded vehicle. This has always been the automotive standard for dimensions. The actual box picture is deleted for clarity of rear measurements.
Second: The rear axle does not move directly up and down because the shackles at the back of the rear springs modify the travel. If you were to load your vehicle weight up to the Gross Vehicle Weight Rating shown in the figures below the diagram, you would probably find a number closer to the 110 target. |
Also as stated earlier the bump stops are not always an exact reference for axle centerline. I know I have my rear axles offset 1" or so from the bump stops so that when the rear leafs compress, which makes them longer and changes the position of the axle, the axle will be centered with the stop under compression.
Your best bet is to mount the bed and get your center line if you have no reference. |
