Schrader Valve on Intake?
The Chilton's on it's way, but in the meantime... What is the schrader valve doing on what looks like the Injector/Intake manifold? what purpose does it serve?...Oh and is my 1988 BII XL R134 compatible??
Thanks again guys... Scott |
Its where you check your fuel pressuer and bleed the pressure off to change the fuel filter and the fuel pressure regulater.
Thanks Grey Ranger, I was mistaken in assuming it was how the injectors were cleaned...Whats the Fuel PSI supposed be? Im used to the German Cars, 80-100 PSI stuff...BTW, I located what I think is the ECU, or brain, under the "B" pillar, behind the driver seat, am I correct?
Thanks Scott |
The fuel pressure should be 35-40 lb with the KOEO.The ECM that you found could be the 4x4 ECM if its a 4x4,or the abs ECM on 2x4s.the ECU is behind the kick panal on the passengres side. You would have to retro fit your ac for R-134.
