300-6 oil presure
Right now in my motor im running 10w30. The presure is at about 35psi at cold start up. then at idle when warm it drops to just under 25psi, and at 1500rpm (my highway rpm) it is pushing about 30psi. does this sound about right. My dad was thinking it seemed a bit low so i was going to put 10w40 oil in it this change. What do you guys think?
300-6 oil presure
That is well within spec...just put in what the motor reccomends. Why fix something that ain't broke?
300-6 oil presure
well i was just asking, my little isuzu truck daily driver runs 75psi cold 25psi warm idle and at 3,000rpm its 50psi.:)
300-6 oil presure
I'm using 15W40 API SL and get 55PSI@1500RPM@45°F and 30 psi@650RPM@185°F water temp.
Regards; |
300-6 oil presure
My 84 runs about 60-70 psi at idle and 80-90 psi at highway speed -2500 RPM. I am running a Mellings high volume pump though:) Actually my Chiltons manual says that is indeed the normal operating range for a 300 six.
300-6 oil presure
Ford says 55psi as maximun. Hydraulic lifter can keep all the way up if valve springs are a bit low of tension, then appears rought idle.
Regards; |
300-6 oil presure
Mine runs about 25psi at warm idle. Yours sounds about right.
300-6 oil presure
Is in range, don't worry yet...
300-6 oil presure
Don't worry for another 200,000 miles and then some...LOL
300-6 oil presure
Originally posted by wildjon300ci Don't worry for another 200,000 miles and then some...LOL |
