Rear cab mount bushings- 4x4
Hey guys, looking to get new cab mount bushings. I'm finding them for the 2wd trucks, but not the 4x4. Anyone have a source for these?
Thanks! |
I quote King (1)
<table width="100%" align="center" class="tborder" id="post14270702" border="0" cellspacing="1" cellpadding="6"><tbody><tr><td class="alt2" style="padding: 0px;"><table width="100%" border="0" cellspacing="6" cellpadding="0"><tbody><tr><td nowrap="nowrap">NumberDummy https://www.ford-trucks.com/forums/i...er_offline.gif ******** type="text/javascript"> vbmenu_register("postmenu_14270702", true); *********>
http://images.ford-trucks.com/forums...bftesilver.gif Ford Parts Specialist </td><td width="100%"> </td><td nowrap="nowrap" valign="top">Join Date: Nov 2006 Location: Hacienda Heights CA Posts: 58,220 https://www.ford-trucks.com/forums/i...tation_pos.gifhttps://www.ford-trucks.com/forums/i...tation_pos.gifhttps://www.ford-trucks.com/forums/i...tation_pos.gifhttps://www.ford-trucks.com/forums/i...tation_pos.gifhttps://www.ford-trucks.com/forums/i...tation_pos.gifhttps://www.ford-trucks.com/forums/i...on_highpos.gifhttps://www.ford-trucks.com/forums/i...on_highpos.gifhttps://www.ford-trucks.com/forums/i...on_highpos.gifhttps://www.ford-trucks.com/forums/i...on_highpos.gifhttps://www.ford-trucks.com/forums/i...on_highpos.gifhttps://www.ford-trucks.com/forums/i...on_highpos.gif </td></tr></tbody></table><!-- / user info --> </td></tr><tr><td class="alt1" id="td_post_14270702"><!-- message, attachments, sig --> <!-- message --> Quote: <table width="100%" border="0" cellspacing="0" cellpadding="6"><tbody><tr><td class="alt2" style="border: 1px inset currentColor; border-image: none;"> Originally Posted by Aesop https://www.ford-trucks.com/forums/i...s/viewpost.gif 4x4 cab mount rubber bushings, does anyone really know? </td></tr></tbody></table> If you had the 1964/72 Ford Truck Parts Catalog, then you would know. Quote: <table width="100%" border="0" cellspacing="0" cellpadding="6"><tbody><tr><td class="alt2" style="border: 1px inset currentColor; border-image: none;"> Originally Posted by Aesop Who actually sells a set for 4x4. Every thread deals with how someone cobbled some mounts together from different kits, machined the pads or made new bushings. The distributors say only good for 2x4. I think all the front bushings will fit, but the aft are slightly thicker than the fronts. Has anyone actually bought a set that fit correctly on a 4x4? </td></tr></tbody></table> Body location #1: 1967/72 F100/250 2WD/4WD & F350 use the same absorbers (aka cushions, bushings, hockey pucks). C4TZ-8100154-C Lower Absorber & C4TZ-8100155-C Upper Absorber ------------------------------------------------------------------------------ Body location #2: 1967/72 F100/250 4WD & F350: C4TZ-8100154-C .. Upper Absorber & C4TZ-8100155-C Lower Absorber. --------------------------------------------------------------------------------- Body location #2: 1967/72 F100/250 2WD use different rear absorbers. C7TZ-8100154-A Upper Absorber & C7TZ-8100155-A Lower Absorber. ------------------------------------------------------------------------------- POST #2 & POST #4: These are not part numbers, they're the ID Engineering numbers marked on the parts. No part numbers marked on parts after 1956, just casting or ID engineering numbers...when applicable. <!-- / message --> <!-- attachments --> <fieldset class="fieldset"><legend>Attached Images</legend> https://www.ford-trucks.com/forums/a...1&d=1397770881 </fieldset> </td></tr></tbody></table> |
and I quote myself
<table width="100%" align="center" class="tborder" id="post14271106" border="0" cellspacing="1" cellpadding="6"><tbody><tr><td class="alt2" style="padding: 0px;"><table width="100%" border="0" cellspacing="6" cellpadding="0"><tbody><tr><td nowrap="nowrap">JEFFFAFA https://www.ford-trucks.com/forums/i...ser_online.gif ******** type="text/javascript"> vbmenu_register("postmenu_14271106", true); *********>
http://images.ford-trucks.com/forums...bftesilver.gif Post Fiend </td><td width="100%"> </td><td nowrap="nowrap" valign="top">Join Date: Mar 2013 Location: Phoenix, Az. Posts: 5,180 https://www.ford-trucks.com/forums/i...tation_pos.gifhttps://www.ford-trucks.com/forums/i...tation_pos.gifhttps://www.ford-trucks.com/forums/i...tation_pos.gifhttps://www.ford-trucks.com/forums/i...tation_pos.gifhttps://www.ford-trucks.com/forums/i...tation_pos.gif </td></tr></tbody></table><!-- / user info --> </td></tr><tr><td class="alt1" id="td_post_14271106"><!-- message, attachments, sig --> <!-- message --> As Bill and I noted above, front and rear take the same rubs. So that means you need 4 of C4TZ8100154C and 4 of C4TZ8100155C. C4TZ8100154C ************** Griese Motors show 2.........405-263-7242 NOS Parts LTD shows 2......972-937-2201 NOS Only shows one..........800-667-6659 Miller Obs shows one..........607-722-5371 --------------------------------------------- C4TZ8100155C *************** Antique Parts shows 2........817-275-2381 Green Sales shows 2..........800-543-4959 </td></tr></tbody></table> |
Ah, the light bulb comes on! I can find the fronts, so I'll just get an extra set of those. Thanks man!!:-X22
So, I had a talk with the product guys at Dennis Carpenter. They make a 2wd kit, but no 4x4. I pointed out that the front bushings are the same on the front as the 2wd, and the rear bushings are the same as the front for the 4x4. I have to call back on Monday, they are going to see if they can put a kit together for me.
Originally Posted by 67nukeford
(Post 15347583)
It seems that mods and chapter leaders can send P/M's to members that have the feature turned off. I then sent you an email asking you to send me the request back, you never responded. Post #3: inre to C4TZ-8100155-C = This is old info, Antique [Auto] Parts is out of business. Excluding Green Sales, there are 5 new sources. Updated info: NOS PARTS LTD in Waxahachie TX has 1 = 972-937-2201. MCDONALD OBSOLETE PARTS CO. in Rockport IN has 1 = 812-359-4965. GREEN SALES CO. in Cincinnati OH has 2 = 800-543-4959. KAMA OBSOLETE PARTS in East Bethel MN has 2 = 763-434-0123. CARPENTER NOS OBSOLETE PARTS in Concord NC has 2 = 800-476-9653. HIGH BUCK! BOB ALLEN FORD in Overland Park KS has 3 = 800-676-0675. |
Sorry, Bill. Didn't get the email for some reason. Anyway, I'm looking for the 4x4 mounts, I need the rubber bushing, washers, bolts, nuts and the metal bushings that go up into the rubber mounts. Found them in the CD illustrations, still working out how to find them in the parts listing pdf.
2 Attachment(s)
Left: Caption should read: 1964/72 F100/250 2WD & 1966/72 F100 4WD
Right: Body text section 000 begins on page 29, this is where the parts can be found. |
Okay, thanks Bill, let me go check that out.
So, after getting all the part #'s for the mounts, I called Dennis Carpenter. Told them what I was looking for, and since they only offer the kit in 2wd form, I explained about how the front absorbers for the 2wd, are the same for the 4x4. He is going to do some checking, and get back to me tomorrow. Maybe I can convince them to offer this as a kit from now on.
Oh, and I'll talk to them about repopping that panel on the inside of the cab corners, also. |
Just thought I'd update this, Bart at Dennis Carpenter has thrown a set of these bushings, washers, and inserts together for me. He said that they are looking into going ahead and making a kit for these to offer for sale.
Sorry Nuke buddy, I have a set down in Baja, I bought off the internet, about 3 years ago, and have not used. Mine were too good to trash, so put them back on when I did the cab off restoration. If you cannot find some, keep up with me, and I will bring them North, in Sept. when I come. I don't plan on pulling my cab ever again.
Baja |
Thanks, Baja, I appreciate it!
