Sending Unit ?
Okay, I replaced the gas tank and sending unit in my 51' F2. Runs much better now (surprise). Anyway The gas gauge isn't moving, so I either messed up installing the sending unit (Thought I put it in the correct direction) or something else is wrong. I know I have several things that need rewired on my truck. Even though it looks nice, one of the previous owners thought it would be smart just to electric tape all the wires vice replace them since they were losing all the shielding.
So the question is Which direction does the sending unit go on the in Cab gas tank? and will Negative ground 6 volt make a difference. Thanks in advance, Joey 1951 F2 |
Hey Joey,
A few questions back your way.. Does your truck have the stock gauges or after market? There are several different "standards" for the gauges & sending units. They need to match up. Example in our '50 we replaced the gauges with modern ones that read 0 - 200 ohms Empty to Full. We used a '70 Mustang tank with a sending unit that read 11 ohms to 78 ohms empty to Full. That didn't work - the sending unit & gauges weren't compatible. We soldered a Universal Sending Unit on our's & now it sends it's readings from 0hms to 200 ohms matching the gauge. If your gauges are stock & the sending unit matches - I'd look for the ground wire to be a problem. Good luck over there. I wish we had Skyline Chili over here in Texas. Ben in Austin 1950 F1 |
Originally Posted by ben73058
(Post 15327900)
Charlie,
You are making me hungry over here!!! I miss those little short hotdogs... Never been to Graeter's - Our Bluebell Ice Cream all got recalled - might need to investigate Graeter's.... Ben in Austin 1950 F1 |
(Post 15327900)
Hey Joey,
A few questions back your way.. Does your truck have the stock gauges or after market? There are several different "standards" for the gauges & sending units. They need to match up. Example in our '50 we replaced the gauges with modern ones that read 0 - 200 ohms Empty to Full. We used a '70 Mustang tank with a sending unit that read 11 ohms to 78 ohms empty to Full. That didn't work - the sending unit & gauges weren't compatible. We soldered a Universal Sending Unit on our's & now it sends it's readings from 0hms to 200 ohms matching the gauge. If your gauges are stock & the sending unit matches - I'd look for the ground wire to be a problem. Good luck over there. I wish we had Skyline Chili over here in Texas. Ben in Austin 1950 F1 As far as skyline, I have one about 2 miles from the house. But I will have to say I prefer the root beer stands chili cheese sandwich. Not a hot dog fan. |
Originally Posted by Joey4420
(Post 15328503)
Stock gauge and bought a replacement stock sending unit from LMC truck same place I got new gas tank.
Float end goes towards the drivers side.
TractormanBill |
Originally Posted by tractormanbill
(Post 15329178)
TractormanBill http://www.lmctruck.com/icatalog/fa/full.aspx?Page=31 Sending unit for the in-cab top right of page 31. |
