E99 7.3 checkup
Hey guys,
I've got and early 99 F250 and the engine is coming out next week to do an oil pan, injectors, and glow plugs. I want to know if there is anything else I should be replacing or checking while this is all apart? I'm not sure if it matters but the injectors are stage 1.5's from FFD everything else is OEM parts. |
Up pipes and manifolds. The pipes are spendyour Riffraff Diesel Bellowed Up-pipe Kit 94-Early 99 - Riffraff Diesel Performance but a one time purchase. If your manifolds are leaking about $60 at a machine shop will make them flat again. Not impossible to do with the engine installed but SOOOOOOOOOOOOOO much easier with it out.
When I had a 7.3 I frequented thedieselstop.com. Lot of experienced guys there willing to help out. It's where I first saw posts about Ford transmissions from former Ford transmission engineer Mark Kovalsky, who also posts on these pages.
If your 7.3 is stock, you may want to consider a bigger downpipe, another intake, a better turbo boot ( I used RiffRaff's) and possibly a tuner to wake it up. Had good luck with my DP Tuner. |
Originally Posted by Poncho450
(Post 15280705)
Originally Posted by clem1226
(Post 15280531)
Thanks to both of you!!! |
