F250 Hitch fit my f350?
New member and f350 owner. Need a hitch and have a line on a class V that was on a 2011 F250. My question is will it fit on my 07 F350?
No sticker on the hitch. Any help would be great. |
The Curt application chart shows that this would be the same hitch if installing their brand. So I would assume it would be for other brands including the Ford hitch.
The Curt chart show 1999 to 2015 as being the same hitch. Welcome to the forum, come back often. |
my understanding as an f-350 owner is that the only case in which the i-beam setup is different if we are talking about chasis cab products . but straight up with factory beds are the same.
I saw a new take off f-250 hitch on clist and it was rated pretty low to be on an f-350 espcially if you have a dually. |
Might matter which F-250 the hitch came off of. My 250 has a Class V hitch for the 12,500 tow package. Others may be different if not ordered with the heavier package.
Should be the same. Front end changed but to the best of my knowledge no frame hole changes on the rear.
